under pulley problems!
Old Aug 17, 2006 | 11:25 PM
99torchredlb's Avatar
99torchredlb
Default under pulley problems!
I have gone thru my 3rd under pulley it always comes loose. Any sure way to keep it tight on the crank? Sure pin or something?
Old Aug 18, 2006 | 12:01 AM
SLPRC5's Avatar
SLPRC5
Here is the advice I got from one of the forum members who is an expert at this.
"One suggestion on the ASP pulley: they are really difficult to get all the way on, that's why you hear about them coming off occasionally.
I twisted until I was blue, thought sure I had it. But I had made some very careful measurements, and discovered it was still not on. So I went at it until
I thought the bolt or my arm would break. Finally it hit a solid stop, then I did the new bolt and the torque/degree thing per the book.
if you have any concern at all, sneak up under there and mark the bolt head and the pulley with a red marker, so you can see if the bolt moves - then just check it once in awhile with a small mirror.
I did this a few times after i ran it a bit hard, just sleep better knowing it's all on well."
Old Aug 18, 2006 | 12:05 AM
99torchredlb
Thanks such a pain in the ***
Old Aug 18, 2006 | 12:13 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Save yourself a LOT of grief; just pin it. All your issues go away, it's a small amount of work esp. if you are now on your 4th install!
Old Aug 18, 2006 | 12:51 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Originally Posted by Dan_the_C5_Man
Save yourself a LOT of grief; just pin it. All your issues go away, it's a small amount of work esp. if you are not on your 4th install!
Old Aug 18, 2006 | 08:38 AM
see5's Avatar
see5
Or use an ARP bolt.
Old Aug 18, 2006 | 10:08 AM
mfrejek's Avatar
mfrejek
I believe the definition of insanity is: repeated action with an expected different outcome.
Old Aug 18, 2006 | 10:26 AM
Sales@HPE's Avatar
0Sales@HPE
Former Vendor
Did you use a new bolt when doing the install? The factory crank bolt is not reusable, it's torque to yield. One use, then throw it away. They're 5 dollars at the dealership. If you didn't do this then that is definitely why you are having your problems...
Chuck @ HPE
281-448-1300
Old Aug 19, 2006 | 01:44 AM
99torchredlb
New bolt every time
Old Aug 19, 2006 | 01:45 AM
99torchredlb
What do you mean by pin it?
Old Aug 19, 2006 | 08:14 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Pinned & ARP Bolt!
Originally Posted by see5
Or use an ARP bolt.
I pinned my U/D pulley (A&A kit) and also used the ARP bolt. While I only have 420 rwhp, I sleep good at night knowing my pulley is secure.
A&A's pinning kit is easy to use. They give you a bolt/guide that you install on the crank/pulley and drill out. Then you tap in a drift pin and it stops the pulley from spinning.
Bob K.
Old Aug 19, 2006 | 11:50 AM
99torchredlb
thaks Bob we FRC guys got to stick together
To under pulley problems!
