Differential Fluid Change
Old Sep 8, 2001 | 04:58 PM
THamilton's Avatar
THamilton
Default Differential Fluid Change
I've just posted this to the Tech Topic section. But since it won't show up for awhile, I'm posting here so I can see what it looks like:
I just finished changing from the stock Differential Fluid to Red Line. I searched unsuccessfully for tips on how to do this without making a mess and came up empty. So now that I have figured out an easy, clean way to do it, I thought I'd share it with everyone else.
1) After driving your car until it is warm, raise it up high enough to get to both the Fill and Drain Plugs. It should be level, just like changing the oil. A lift obviously makes it very easy.
2) Loosen, but do not remove the Fill Plug.
3) Place a drain pan under the differential and remove the Drain Plug.
Removing the Fill Plug at this time helps it to drain.
4) Let the stinky old fluid drain completely. I left it over night.
5)Wipe the drain and Fill Areas completely.
6) Reinstall the Drain Plug. Tighten to 26 ft-lbs.
7) Fill until some fluid seaps out through the Fill port. It should take about 1.6 Qts.
8) Re-install the Fill Plug. Tighten to 26 ft-lbs.
9)Go for a drive and check for leaks.
To make life easier, I made a special fill tube from some flexible PCV tubing hot glued to the cap off one bottle of fluid.
[Modified by THamilton, 8:39 AM 9/9/2001]
Old Sep 8, 2001 | 05:28 PM
carpe dm's Avatar
carpe dm
Default Re: Differential Fluid Change (THamilton)
Great pictures and write up. I'm glad you mentioned the fill plug first; don't want to drain it and then find that you can't get the drain plug out!! What did you do about the Limited Slip Additive? I did mine with Mobil 1 synthetic, but made sure to use the LSA too. :yesnod:
Old Sep 8, 2001 | 10:05 PM
THamilton's Avatar
THamilton
Default Re: Differential Fluid Change (carpe dm)
Carpe,
thanks for the kind words. The Red Line juice I used came with the LSA pre-mixed. Made life easy for me.
Old Sep 8, 2001 | 10:28 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
great tips :D
Mark
Old Sep 8, 2001 | 11:53 PM
CJS's Avatar
CJS
Default Re: Differential Fluid Change (Mean Green 2000)
Thanks for the excellent write up, I am going to do mine soon. One question though, is there enough room near the differential to get the bottle and that short hose in position for the gear oil to flow out of the bottle completely? In the pictures it looks, like only a half a bottle worth will go in?
Old Sep 9, 2001 | 10:36 AM
THamilton's Avatar
THamilton
Default Re: Differential Fluid Change (CJS)
CJS,
That's a good question.
Actually, the oil won't flow at all, even when you tip the bottle hose down. You need to squeeze the bottle over and over to get the oil into the differential.
It might flow if you poke a hole in the bottom of the bottle, but I didn't want to make a mess. Also, the second bottle doesn't get used completely so a hole would be inconvenient.
Old Sep 9, 2001 | 12:21 PM
BOBSZ06's Avatar
BOBSZ06
Nice write-up! I did the very same thing about 5 months back. I did however buy a cheap hand pump which fits into the mouth of the Redline bottle. Worked well for me.
Old Sep 9, 2001 | 03:15 PM
BobG's Avatar
BobG
Default Re: Differential Fluid Change (BOBSZ06)
A little tip....a couple minutes in a microwave right before filling makes the new oil flow a little bit faster...
To Differential Fluid Change
