Trouble shifting into first
Old Aug 20, 2006 | 10:33 AM
stormrider's Avatar
stormrider
Default Trouble shifting into first
I have an 02 M6 with about 51k on her. Lately from a stop I am having trouble shifting from neutral into 1st gear (not everytime but enough times that it is starting to concern me). Is this normal? If not what can I do to fix this issue? Thanks!!!!!
Old Aug 20, 2006 | 10:45 AM
EHS's Avatar
EHS
This comes up all the time.
Most of that time it's normal.
Try an different gear first, then go back to first.
Try letting the clutch out a bit, then go back.
It's how a manual transmission works:
http://static.howstuffworks.com/flash/transmission.swf
Old Aug 20, 2006 | 11:03 AM
DeeGee's Avatar
DeeGee
I've also had similar issues when the clutch started to go bad on the Camaro.
Old Aug 20, 2006 | 12:08 PM
cenzo's Avatar
cenzo
If you haven't done it yet, replace the tranny fluid with one of the popular synthetics...Mobil 1, Amsoil, Royal Purple, etc. I'll bet it gets better!
To Trouble shifting into first
