MN6 help!
Old Aug 22, 2006 | 02:42 PM
nastymant's Avatar
nastymant
Default MN6 help!
My tranny will jump out of 1st gear unless i double clutch it and gears will grind unless i match engine speed. I've been reading on the forum that a simple fluid change might fix this? Is this true?
I was thinking about either finding a new tranny to swap out or overhauling the original one myself.
1. How difficult is it to remove a 6-speed in the home garage (i do have gm service manuals)?
2. If i wanted to swap out, would a mn12 bolt right up with no modifications?
thanks for your help!
i have a 98 coupe with 82,000 miles, stock 6 speed trans
Old Aug 22, 2006 | 07:43 PM
nastymant's Avatar
nastymant
anyone!!??!!
Old Aug 22, 2006 | 08:00 PM
Jay-rod's Avatar
Jay-rod
I would change the fluid first.these trannies act very funny if they are either low or the fluid is broken down.JER
Old Aug 23, 2006 | 07:24 AM
fdxpilot's Avatar
fdxpilot
Sounds like your synchros on 1st are shot. I had the same problem on Reverse in an F-body T56
To MN6 help!
