AC stinks on startup
But even if your drains are not clogged, it's not uncommon to have that musty smell come from the AC. The problem is that you are shutting off the car while there is moisture still in the system, and you probably have some mold growing. You may need to clean it (sometimes just spraying some Lysol in the air intakes along the windshield will suffice) to remove the funk. After it's cleared up, try shutting the AC off about 45 seconds-1 minute before you are planning to stop and turn the engine off, but with the fan still running (I do it when I'm about a half mile or so on my way home). This should allow enough time for the unit to dry out, and you won't have that musty smell coming back.
thats what I do, and it smells like chicken!
j/k!
Let the car idle and turn up the heat full blast for a few minutes. Make sure to switch between settings of outside/inside circulation. The heat seems to do a good job of drying up air system.
Repeat as necessary when the smell comes back.
Charlie
