AC stinks on startup
Charlie
But even if your drains are not clogged, it's not uncommon to have that musty smell come from the AC. The problem is that you are shutting off the car while there is moisture still in the system, and you probably have some mold growing. You may need to clean it (sometimes just spraying some Lysol in the air intakes along the windshield will suffice) to remove the funk. After it's cleared up, try shutting the AC off about 45 seconds-1 minute before you are planning to stop and turn the engine off, but with the fan still running (I do it when I'm about a half mile or so on my way home). This should allow enough time for the unit to dry out, and you won't have that musty smell coming back.
And us Florida residents should know a thing or two about humidity.
Charlie
Charlie
There are THREE cowl drains on the drivers side of the car and one on the passengers side. If those drains are clogged with leaves, sticks and trash, your going to get a horrible musty smell just as you described. Give this a shot and see if it helps:
Examine the THREE DRAINS on the drivers side. See if there full of nasty leaf junk:
[IMG]http://img.photobucket.com/albums/v402/bill327/DriversidecowldrainsII.jpg[/IMG]
If you squeeze the soft rubber udders and there hard, there full of crap and that stuff will really stink!!!
If there is lots of leaf matter in the area below the cowl, you may need to remove the cowl and clean that area out.
On the other side behind the battery, there is one single tube that is larger in diameter and much longer. I disconnect it from the top and blast water through it. If there is any trash in it, the water will blast it out the lower end:
The tube is long and reminds me of something that you see in a monster movie:
If you remove the tube, its tough to get it back in the same hole. It best to just spray water in the other end (upper end) of the hose.
Once the drains are clean, see if the smell is gone.
BC
Thanks for the info, I had already read your hints on the tech sticky thread. Mine did have stuff in the udders. But it still has a little musty smell on start up. The AC drain works as water drips on the floor as the unit runs so I am this point now.
While we are at it, any clues on how to loosen up the wipers for removal. The nuts came off fine but the arms are not budging.
I don't know if they put in the anti mold stuff, or not.
If you have warranty left, and can combine it with another fix, it's worth it.
It's much smaller than the ones shown in Bill's photos. If it is blocked, your evap core housing will fill with condensed water and the passenger floor carpet will get wet so it's worth checking every time you lift the car for maintenance.
It looks just like this:
And it lives here:
Thanks for all the detailed photos. I know this has been posted before but its a good reminder for others
