clutch sticking?!?!
Old Aug 24, 2006 | 11:42 PM
2wdchevy's Avatar
2wdchevy
Default clutch sticking?!?!
I took my car to the trach tonight and on every run my clutch would stick back when shifted to second (happened on 4 out of 4 runs). The first time the pedal stayed all the way back to the floor (had to use my foot to pull it forward). next time wasnt too bad. Third run it only came back likte 2 inches and was able to shift, but isnt right. last run it stuck to the floor again, so i just coasted down the rest of the track hoping not to do any damage. Clutch petal seemed very light afterward and smell of burnt clutch has strong.
Anyway, to wind the story down, i fulled up with brake fluid because it was about 1/4 low and seemed to get rid of a little shudder when starting off in 1st. Problem is that I have never had a problem with the clutch and seemed to drive fine on the way home. WHY ONLY AT THE TRACK?? Has this happened to anyone else and if so, is it only because the fluid was low...or do I have a bigger problem to deal with. I have a 98 M6 vert. Any help would be appreciated.
Thanks,
Greg
Old Aug 25, 2006 | 01:32 AM
Z06-Goose's Avatar
Z06-Goose
Thanks,
Greg
Change your fuid, and do it often. It happened at the track because it gets hotter.
Read this link below. Excellent advice by Ranger, plus a couple of other links that will enhance you
http://forums.corvetteforum.com/show....php?t=1478581
Goose
Old Aug 25, 2006 | 12:57 PM
Ranger's Avatar
Ranger
Goose
Good points, Goose.
Here is the operative collection of threads.
Why and how to take care of your clutch fluid.
Ranger
Old Aug 26, 2006 | 10:54 AM
2wdchevy's Avatar
2wdchevy
Thanks for your help. I was hoping that it was not anything major or that my clutch was done for. Hopefully once all the fluid is changed out it will work fine.
To clutch sticking?!?!
