New heads = zero hp gain
Old Aug 27, 2006 | 07:51 AM
minytrker's Avatar
minytrker
Default New heads = zero hp gain
I sent my stock 242 heads off to a well known shop and had them do there magic, port, polish, valve job, and so on. I also went with thinner head gaskets per there instruction. I also added bigger injectors. I had 430/390 before and did 430/390 after the heads. Per the machine shop I needed .005 shorter push rods, so I swapped them out. I retuned the car but it doesnt seem any faster and gets 5-6mpg less now vs before the heads. The machine shop says thats from the bigger injectors. I can see from the data that the heads are flowing more air. I am going to re-dyno it this week to see the push rods fixed the problem. My car is no faster than before so Im guessing it isnt going to dyno anymore hp again. Any ideas?
Old Aug 27, 2006 | 10:15 AM
AU N EGL's Avatar
AU N EGL
you put new heads but did not retune your car??
Tuning is the key to performance, not bolt ons on any car.
When major bolt ons are added a new tune is a must.
Old Aug 27, 2006 | 10:45 AM
billiardcue's Avatar
billiardcue
If you didn't reprogram the computer for the larger injectors that would account for the loss in fuel mileage and the extra rich condition will reduce hp.
Old Aug 27, 2006 | 10:58 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Tuning/programming is the most important part.
Old Aug 27, 2006 | 11:07 AM
SpeedyZ's Avatar
SpeedyZ
The stock LSx heads do a remarkably good job in a stock configuration. Putting high flowing heads on a other wise stock engine is not going to gain much and can hurt performance in some cases. Reason being is you will loose port velocity, meaning the air speed in the ports will be much lower even though your max flow is higher. The cam is where the performance is! Now if you change the cam you will see the gain from those high flowing heads. Of course LT headers will help a lot too, specially with a good cam. The push rods .005 shorter will not fix your problem.
Old Aug 27, 2006 | 12:10 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
stock injectors are good to 450 RWHP miine are stock
Old Aug 27, 2006 | 01:52 PM
Silver Z06 Driver's Avatar
Silver Z06 Driver
Default Port-job
Right on target
You've got to bump up your Lift & Duration to extract the hidden power from that port-job. Long Tubes to top it off. Injectors will help with future mods, but not necesary so far.
Old Aug 27, 2006 | 02:12 PM
crazyburner's Avatar
crazyburner
Default Lingenfelter kit
sorry , i've made a mistake
Old Aug 27, 2006 | 05:49 PM
minytrker's Avatar
minytrker
I already have every bolton and a cam......430rwhp/430rwtq before the heads. I just didnt bolt on a set of heads on a stock car. The car has been retuned for the heads and injectors. It is not running rich, I have a wideband in the car to double check. The stock injectors were maxed out over 100% duty cycle, I also have nitrous on the car so I need bigger than stock injectors.
Old Aug 27, 2006 | 10:40 PM
SpeedyZ's Avatar
SpeedyZ
Oops, sorry about that, I looked in your profile before under mods and seen "bolt ons & tuned" but didn't see your sig until now. So I assume the 430rwhp/430rwtq is without nitrous, correct? You shouldn't have needed larger injectors for a wet shot nitrous. Almost sounds like your nitrous system is not supplying enough fuel. Are you watching fuel pressure? Something don't add up because with that cam you should have seen some gain from those heads. Intake and TB still stock? What kind of number are you seeing on the nitrous?
Old Aug 27, 2006 | 10:47 PM
chriswtx's Avatar
chriswtx
Did you actually measure the lifter preload or just take their word for it?? You might want to actually measure the preload on the lifters...
Old Aug 28, 2006 | 01:28 AM
minytrker's Avatar
minytrker
I have only sprayed it a few times with very small shots just to make sure the nitrous was working.
Old Aug 28, 2006 | 01:30 AM
427CPE's Avatar
427CPE
Which heads did you get? The stockers I thought were labeled 243's. You sure you didn't get back someone elses LS1 heads?
Old Aug 28, 2006 | 01:31 AM
minytrker's Avatar
minytrker
I measured it by counting how may 1/4 turns it took to reach 22ft pounds. I know its not the most correct way but it showed I had way to much preload.
Old Aug 28, 2006 | 04:16 AM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
You should have about a turn and a half to two full turns from zero lash to fully torqued....if you do, pushrod length is not the culprit.
If the heads were opened up a bunch with minimal gains in airflow you will experience similar results to what you described (minimal power gains, sluggish/lazy part throttle, and poor fuel economy). I have seen some 240+ cc ports that could parctically swallow a golf ball barely muster 300 CFM. Airspeed in that situation and subsequently the ramming effect from inertia are both compromised, hurting performance. Also, the bigger lazier ports are more prone to reversion once again due to the fact a slower traveling column of air doesn't have as much energy/momentum and is more likely to change direction.
Whether any of what I just mentioned applies (to your scenario) is anybody's guess but trust me that the situation I just descibed is not that uncommon.
Old Aug 28, 2006 | 04:45 PM
minytrker's Avatar
minytrker
I have 1-1.5 turns now, with the old push rods I had 2.5 turns. Yeah Im lost, the shop that did the work is saying they have never seen less that 20rwhp gain on any car. It really sucks going from 430/390 at the wheels & getting 30-31mpg to 430/390 and getting 23-24mpg.
Old Aug 28, 2006 | 05:36 PM
Old geezer's Avatar
Old geezer
Default ????????????
You said:"Per the machine shop I needed .005 shorter push rods, so I swapped them out."
I'm confused. The .005" reduction in p rod length equates to 1 less turn of the adjuster???
Are you sure they didn't say .050" shorter?
.005" is a mighty small differece to get for a choice in p rod lengths.. .050", yes. .005", I doubt it, unless someone is really splitting hairs.
To New heads = zero hp gain
Old Aug 28, 2006 | 05:52 PM
vettenuts's Avatar
vettenuts
You aren't by any chance running the Comp R lifters, are you?
Who did the porting?
Old Aug 28, 2006 | 06:06 PM
minytrker's Avatar
minytrker
I went from 7.4s to 7.350's.
Old Aug 28, 2006 | 06:10 PM
minytrker's Avatar
minytrker
Yes I comp r lifters.
I would rather not say until all this is resolved, they are a supporting vendor.
