New 1997 C5 that needs mods
Old Aug 27, 2006 | 12:52 PM
ultradriver10000's Avatar
ultradriver10000
Default New 1997 C5 that needs mods
I just baught a 1997 m6 and was woundering what kind of mods will give me the best bang for the buck? It already has a K&N and a Corsa exhuast but that is about it. I'd like to get it to be a consistent 12 second car. I have a wet nos system laying around and was thinking about a 100 shot? I'd still like to get it to be low 12's all engine. Let me know what you guys think. Thanks alot!
Old Aug 27, 2006 | 03:36 PM
pawngod's Avatar
pawngod
hey!! mines a 97...nice ride........i wouldnt push the engine on this years..i read they have weak rod bolts....BUT mine has 100.000 miles on same engine and trans...still runnin strong
Old Aug 27, 2006 | 04:19 PM
123sugey's Avatar
123sugey
Dig
Try 3:90 Gears In The Rear
Sticky Tires Are Also Needed
Your Goal Is Not Hard
I Have 115,000 Miles On My A4 1997 And Have Not Had Any Problems With My Short Block With..... Alot..... Of Nitrous Use
Old Aug 27, 2006 | 06:41 PM
ultradriver10000
sounds good guys ...mine only has 30,000 miles on her and I just want to quicken her up some. Would you guys suggest long tub headers and just a good tune ? Is there any good intake options ? I really have no information on what i can do to this beast to increase it performence wise. How is that skip shift eliminator ? I don't seem to have a problem with the 1-4 thing it hardly ever makes me shift like that. I think from the factory I have 3.42 gears will 3.90's make a huge difference? or should i just go 4.10 ? How hard is it to swap the gears? Thanks for all your help!
Old Aug 28, 2006 | 08:48 AM
ROJO99's Avatar
ROJO99
LT headers, Vararam and DR's put me at a best of 12.20@114 with an average of 12.5. You will likely run into clutch issues like I have. Once you begin to approach the 11.99 barrier the stock clutch is the weak link. So be prepared to upgrade this also.
The juice will be a great add on. I keep thinking of adding this for giggles myself.
Old Aug 28, 2006 | 09:47 AM
byte_me's Avatar
byte_me
1) Long tube headers- with or with out CATS (+ 25 HP to the wheels)
2) LS6 intake manifold (A few more ponies, great combo with above)
3) High Flow Intake air system (VARARAM)
4) Good Dyno Tune
5) Drag Radials to hook up
I ran a flat 13.1 @ 108 in my stock 97 A4 with run flats...this was with a 2.+ 60' time (could not hook up with run flats)
you will be easily in the 12's with the above set of mods...
Old Aug 28, 2006 | 05:28 PM
JSTAN's Avatar
JSTAN
Get a supercharger...after you get into the 12's you will then want to get into the 11's and so on.
Old Aug 28, 2006 | 06:54 PM
ultradriver10000
Some more pictures for you guys....what kinda dumb **** gets vette racing flags across his back ? ME hahahah
Old Sep 6, 2006 | 01:54 AM
ultradriver10000
nada ?
Old Sep 6, 2006 | 07:49 AM
c5chines's Avatar
c5chines
Default 97 mods...
I have a 97 torch red A4. I also have a wet system laying around and have been tossing around putting it on with a 75-100 hp shot.The engine will live with a 100 shot, but I wouldn't try the 150 without some other engine mods. Use a window switch for the nitrous control due to the drive by wire and make sure you add a fuel pressure switch too. The "experts say that you don't really want to have the A4 shift on the bottle and that there are programmers that will interrupt the nitrous feed during shifts. Guaranteed 12's all the time with no other mods. As far as bang for the buck, nitrous is unbeatable provided you do your homework and follow the manufacturers instructions to the letter. Chuck.
Old Sep 6, 2006 | 08:08 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Nice car welcome to the forum....
Do gears, cam and headers - you will run low 12s all the time. If you have some extra bucks change the heads.
Old Sep 6, 2006 | 10:10 AM
97C5ENVY's Avatar
97C5ENVY
A good Cam, Long-Tube Headers, a set of gears (3:90 or 4:10), and good tune will get you where you want to be. Keep in mind that with increased power comes decreased traction, so you'll need some good DR's too.
Old Sep 6, 2006 | 10:44 AM
MR.KIDD's Avatar
MR.KIDD
[QUOTE=ROJO99]LT headers, Vararam and DR's put me at a best of 12.20@114 with an average of 12.5. You will likely run into clutch issues like I have.
Not trying to hog this post but I have to ask your running 12.20s and all you did was headers,Vararam and DR's no cam or head work or did I miss something,reason for asking is I'm getting ready to purchase a 98 with automatic and would like it to run that good with mods like that.
Old Sep 6, 2006 | 10:59 AM
Wicked Weasel
you will not run 12.20s with only headers, vararam and DRs.
Old Sep 6, 2006 | 11:38 AM
Billdog350's Avatar
Billdog350
I'm with Weasel. I have LT's, a custom tune, no CATS, and a vararam and my best was a 13.3 @107 with my MN6 but my clutch is slipping pretty badly (115k orig miles) so I might get a bit more just from that. Granted I was running horrible 60ft times with my stock tires and bad clutch, but 12's with just LT's is pretty high hopes.
Old Sep 6, 2006 | 11:42 AM
Billdog350's Avatar
Billdog350
Yep, the key word being CAM. Most good cams are good for 50-75rwhp on our LS1's when properly tuned (with LT's and good CAI).
Old Sep 7, 2006 | 12:38 AM
4DRUSH's Avatar
4DRUSH
To New 1997 C5 that needs mods
Old Sep 7, 2006 | 03:59 AM
mdhmi's Avatar
mdhmi
Twin Turbos.
Old Sep 7, 2006 | 09:42 PM
ultradriver10000
well all i need is money...does anyone know where that damn money tree is again ?
Old Sep 7, 2006 | 09:59 PM
JropTop's Avatar
JropTop
with 3.90 gears,drag radials,vararam,tpis headers and exhaust i ran an 11.9 @ englishtown with a mn6,so it is possible!
