4.155 bore potential with plenty of wall thickness and integrity....less chance of a problem when compared to the wetsleeve process and half the cost of a C5R. Strong because the OD of the LS2 blocks are beefy even after having the material removed for the ductile sleeves.
Or as others mentioned save your money and build a killer 402....similar power but less TQ (assuming the same induction) which might be a good thing depending on your set-up.
From: Buy USA products! Check the label! Employ Americans
some tuners won't do a 427 Darton. They have had problems then have to redo the entire job and eat it. If I was doing a 427 I do the C5R block. I'll probably do a 402 in the future when mine pops.
Originally Posted by mdhmi
If the LS2 block is $1,000 and the Darton sleeving proces is another $3,000 then the C5-R would be tempting as it's only another $2,000.
And how much does a nice 427 cost to build? Two grand is not in the picture if I am spending 20,000 I'd go for it. I got prices in the 25-30,000 for a good 427.
I was just showing a comparison of the price difference between Darton and C5R 427s. You can almost always undercut LPE on price, but when you look at their results, reputation, 2 yr warranty, and resale value, many feel the price is worth it. I'm more inclined to get work done by them or their sister shop, 21CMC, than so no-name "low-ball price shop", but that's just my opinion.
One could go this route. Putting darn good parts for road race relaibilty on a C5R block I was up to $19G plus labor.
I have also looked at a Darton Sleeved GM LS2 block and a Katech Block LS2 427's.
Dont forget IMHO the most important part, what do you want the engine to do?? How many RPMs do you want to spin? How much TQ and HP are you looking for? Reliabilty issues?
Dont do cheap parts when building an engine, It cost less to spend more when building it right the first time, then to build it cheap two or three times.
