Had a Tire Pressue Scare today.
Old Sep 1, 2006 | 05:58 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Default Had a Tire Pressue Scare today.
I've got a slow leak from the O-ring on my right rear tire aparrently, so today I stopped to add a couple pounds of pressure prior to hitting the dyno. I decided to bump up the left rear also while I was at it.
After about a 20 minute drive, I was clicking through the DIC and when I hit the rear tire pressures, had a shock. The left rear was at 25 PSI and went down to 23 over the course of the next 5 minutes while I made my way through downtown philly to the dyno shop.
Get there, don't feel any protrusions from the tire, but I can HEAR a faint hiss. Pull the valve cap off and it got louder. Took a look, and there was a VERY tiny O-Ring half wedged in the tip of the stem slightly depressing the core. I have no idea where it came from, but removed it and all is well. Probably came from the gas station tire inflator tip somehow.
Old Sep 2, 2006 | 12:38 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
That tiny o-ring was from the valve stem cap itself.. Sometimes they work loose, I have one like that as well.
Old Sep 2, 2006 | 11:35 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
Really? Is it ok to toss it?? Whoops.
Old Sep 2, 2006 | 12:46 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Yep, I had the exact same thing. I then bought a set of the cheapo plain black plastic caps and took the flat style washers out of them to use. The o-ring type seem to come out too easily and cause the problem. weird............
Old Sep 2, 2006 | 12:53 PM
Dan_the_C5_Man
Well, they are designed to stop a leak at high speed where the inertia of the spinning wheel could potentially un-seat the valve from the stem.. More of an issue on a 180 MPH Superbike than it is on a street car.
To Had a Tire Pressue Scare today.
