Airbag light on after header install
Old Sep 4, 2006 | 11:17 PM
FRC Shopper's Avatar
FRC Shopper
Default Airbag light on after header install
I just installed a set of headers, and now my airbag light is on. It never illuminated before this. I'm not sure what could have happened during to install to set this off. The steering shaft was disconnected during the install, but I'm not sure if it's related to this problem. Any ideas?
Old Sep 5, 2006 | 01:14 AM
99FewteRC5's Avatar
99FewteRC5
if the steering wheel was turned with the shaft disconnected the sir coil (clock spring) could have been damaged. Check the codes, if its the clock spring it should set a code for the clock spring.
Old Sep 5, 2006 | 08:19 AM
VetteTech81's Avatar
VetteTech81
I agree with that... Check codes and see what is being flagged...
-=Rick
Old Sep 5, 2006 | 02:38 PM
FRC Shopper
Good call. The steering wheel was turned with the shaft disconnected, and now the car's throwing code B0026. Where is the clock spring located? How much does a new one cost and how difficult is it to replace?
Old Sep 5, 2006 | 07:21 PM
VetteTech81
It's behind the steering wheel, the wheel must be pulled to replace it.. as for cost not sure... I would check with a dealer... as I'm not sure it's availble aftermarket...
-=Rick
Old Sep 5, 2006 | 09:12 PM
FRC Shopper
-=Rick
Wow. That sounds like a fun job. Now I get to pull the steering wheel. Yippee!
Seriously, though, thanks for your help.
Old Sep 6, 2006 | 12:34 AM
FRC Shopper
I found this picture in a search. Is the clock spring visible in this shot? I'm not really sure what I'm looking for. Also, does a broken clock spring mean there's a chance the airbag will explode while I'm driving?
Old Sep 6, 2006 | 08:18 AM
VetteTech81
That's it right there... the round thind with the YELLOW wire... the coil or spring whatever you want to call it is inside the plastic.. you service it as a unit..
As for the air bag going off because the clock spring maybe broken... doubtful... I've seen a few get broken before and people drive with it like that sometimes.. not safe though as the air bag will not work...
Good Luck...
-=Rick
Old Sep 6, 2006 | 12:20 PM
FRC Shopper
Thanks, Rick, you've been a huge help.
Old Sep 6, 2006 | 02:04 PM
VetteTech81
uH OH.. THIS POST IS GOING TO GET LOCKED... I guess the person you borrowed the steering wheel pic didn't like that.. and changed the file....
-=Rick
Old Sep 6, 2006 | 02:15 PM
keliente's Avatar
keliente
OMG I can't believe that picture
To Airbag light on after header install
