This past weekend I attempted HB replacement as well as a cam install with a buddy. As I was away from the car taking a phone call, my buddy attempted to install the UD Harmonic balancer on his own. Once I got off the phone, he tells me the bolt won't back out My question is, is the crank repairable or am I screwed? I put the car back together as best as I could. I did the job due to a wobbling balancer and now is doing exactly the same thing just not as bad.
Thanks in advance
Hope you are sitting down buddy....chances are pretty good that the crank threads are jacked. Now looking on the bright side, you haven't broken the crank bolt off in there yet, so that's a plus.
This is a pretty common problem when trying to install the crank pulley (harmonic balancer) using the crank bolt.
You are sort of screwed. You need a threaded rod to put on the balancer. When you use the bolt, you only engage a couple of threads and as soon as you load it up trying to push on the balancer the threads rip out, the more you turn, the more threads get damaged. There are several threads over on LS1Tech on this, and the way they were fixed. You can try backing it out, but the bolt will likely break and then it is drill and tap time, possibly heli-coil. Read up on this on all the threads you can find before attempting to do anything. The other option is to take it to a machine shop and hope they can take care of it.
If you can move it at all, you can try and come out a bit, then in, then out a bit, then in to see if you can slowly back it out. If it won't move at all, the threads are damaged and likely gauled.
This is the tool I made to re-install the balancer.
Thanks to all your responses. I tried backing out the bolt since I was able to brake it loose. I could reverse the bolt but I would not physically come out. I figured it was stripped to the point that the bolt had nothing to catch on to for it to reverse. I'm hoping one of our fellow corvette member that lives near by could help out. He offered to help out on the install but was unavailable this past weekend. I'll take all of your advice and read up on the issue. I'm hoping I don't need to replace the crank, that was the screwed part Keep the comments going so that I could hopefully find a fix and document it for others benefits.
Vettenuts & Connecticut - are you guys using a grade 5 or grade 8 ready rod, or are you using standard "soft" ready rod to make the pulley installer?
Connecticut - you say M16 thread, what diameter bolt though??
Thanks for the info - I'll be doing this this winter.
Actually, the diameter is the M16, and the thread pitch is 2.0. Factory bolt is 100mm long, and I got a 140mm one to install my Powerbond pulley. Went right on , no problem.
Thanks much, valuable info! At the risk of asking a stupid question, where did you purchase the 140 mm bolt?
If I was to retap, would it be difficult to find a bolt to that will fit the crank? Are there any kits out there for the DIY type? connecticut mentioned a NAPA kit that doesn't work.
Use a heli-coil or Keensert. You tap to a larger size and then install the heli-coil. If you go SAE, you will have bastardized your setup and won't be able to use the stock bolt or the ARP bolt. The proper preload is critical to keeping that thing on there.
The threads in these cranks don't start for like 2" down in the front of the crank so fixing those threads that far down in the hole is next to impossible. What someone on here who broke off the bolt in the crank has done in the past is thread (not re-thread) the larger part of the front of the crank. Then used a much larger shorter bolt. I forget what size bolt they used but I'm pretty sure it was a perfect size to tap without drilling. They machined out a jig that slid over the snout of the crank and the tap threaded through it and it held the tap straight as they threaded the end of the crank. If you have to go this route simply pin the balancer when you install it and it will never go anywhere.
I didn't try putting any pressure to back it out. I wasn't thinking straight. The combination of being pissed off and a few beers did not do well on my senses. I have to strip the car down again and try that. I'm positive I can get the bolt out is just the fixing the threads part I've never done before. I hate to monkey it up more than it already is.
We always just used a longer bolt to pull the pulley on and then switched to the old stock one to tighten it down and then finally to the new bolt just like in the ls1howto instructions recommended (without any problems on about 7 I've seen done this way). Is this not recommended?
Just discovered something new!!! As I was cleaning out my garage last night I found the NEW BOLT that came with the kit. I think my buddy put in the factory bolt back in Could that explain the stripped bolt or is it still possible the crank is screwed up?
