Headlights Opens Slowly?
Old Sep 10, 2006 | 04:37 PM
Eskridge's Avatar
Eskridge
Default Headlights Opens Slowly?
Hey Guys,
My headlights in my 98 C5 opens slowly. Do anyone know what could be causing this?
Thanks,
Mike
Old Sep 10, 2006 | 11:24 PM
JC in XTC5's Avatar
JC in XTC5
It could be a number of things, but here are some ideas.
Are these the original headlight motors (i.e. old plastic gears inside)? It's possible the gears are worn and the teeth are slipping so the headlight will not come up as quick. If you raise them manually, do you feel them opening smoothly? or do they slip? If you find they're not opening smoothly, then you'll likely need to replace the gears with new brass ones:
http://www.rodneydickman.com/corvette.html
If both headlights are opening slowly and it's not the gears, but rather an electrical problem. Try applying an external +12V to the motor wires from to see if they raise normally. If they do, then the problem would be somewhere in the circuit to the motor like the headlight control module. If they still raise slowly then the problem is somewhere in the motors.
