Pulley Replacement Question
Old Sep 15, 2006 | 03:31 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Default Pulley Replacement Question
Going to be tackling the pulley this weekend. Question I have is with the E-Brake on, the M6 in a high gear, will there be enough driveline tension to break loose/torque down the pulley bolt?? Rear tires are in the air right now and the e-brake is suspect, so I presume that putting the rear back down would probably put enough tension there to be adequate. Yes, no?
Old Sep 15, 2006 | 06:28 PM
LoneStarFRC's Avatar
LoneStarFRC
When you say "pulley" I'm assuming you're referring to the crankshaft balancer pulley? If so, you might be better off having the additional friction of the tires on the ground as well. The best way to go is to use a flywheel ring gear stop, but if you don't have one, your method should work too.
Anyone else?
Old Sep 15, 2006 | 07:14 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default pulley
with car in gear, e brake on, if you had a helper they could also stand on the brake, you will have enough vacuum in the reservoir for about 3 applications of brakes, so all you need is just one, and that would suffice.
Old Sep 15, 2006 | 07:55 PM
vettenuts's Avatar
vettenuts
That's how I did mine, no problem. Just make sure you have an installation tool, there's been an awful rash of damaged crank threads lately.
Old Sep 15, 2006 | 10:44 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
Had it for a week now, Hawk618's from LS1Tech.
Old Sep 15, 2006 | 11:41 PM
Jeff Jeff's Avatar
Jeff Jeff
If you do it with the wheels on the ground and the front on jackstands, be careful. If the wheels turn, the vette could lurch forward / backward and cause some damage to you or something else. Lets just say that if I were to do it again, I would probably take the extra effort to use a flywheel locking tool.
Old Sep 16, 2006 | 10:11 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
Did you turn the wheels with the front in the air I presume??
Old Sep 16, 2006 | 10:47 AM
Rex99Coupe's Avatar
Rex99Coupe
Do a search on LS1tech.com/Tools & Fabrication for "Crank Pulley holder".
Several people have made there own, I bought one from code4 last Dec. Haven't used it yet.
To Pulley Replacement Question
