Coilover adjustment issues!???
Sep 17, 2006 | 09:30 PM
Supremacy 1 car at a time
Im giving up on these and buying new ones, 1500 if anyone wants them
Ive spent the last day trying to set my coil overs to be somewhat the same setup. Ive installed and removed them 3 times, set them up and measured them on a bench and when reinstalled I have a 1/2in - 3/4 in difference in ride height from left to right.
Everything goes in identical but ends up way off.
Sep 18, 2006 | 12:44 AM
St. Jude Donor '08
Who's coilover's do you have ?
Where are measuring from ?
You should verify that you are on level ground. All measurements should be to the frame and not the fenders.
If you off only remove the one you want to adjust and make change.
Sep 18, 2006 | 03:49 AM
On my DRM's I carefully measured the spring preload (from the last thread to the bottom of the adjustment collar) and the ride height is dead-on even.
Sep 18, 2006 | 05:59 AM
I have the DRMs as well and thats the same way im measuring them and it still comes out to be off.
Sep 18, 2006 | 12:06 PM
Did you check to see if the springs supplied were the same side to side (hard to believe Randy would have missed that).
Not sure what's going on here, unless your sway bars are loading the suspension for some reason.
Sep 18, 2006 | 01:42 PM
IM going to take the swaybar off tonight and try everything without it on.
Sep 18, 2006 | 09:51 PM
nothins workin theyre coming off and getting sold
Sep 18, 2006 | 10:02 PM
Quote:
how do u like the coil overs? how do they compare to the t1 setup? what sway bars are u using? do u want to go to the mtns sunday?
Sep 18, 2006 | 10:35 PM
St. Jude Donor '08
Don't be so fast tempered. If I were home I would give you hand but at the momement I'm 3500 miles away in Vancouver, BC.
I posted a link to a local shop that could help you.
http://www.phoenixperformanceinc.com/
Sep 18, 2006 | 11:19 PM
From: Buy USA products! Check the label! Employ Americans
have you called DRM and ask Randy for some tips?
Sep 19, 2006 | 05:38 PM
Something just isn't right here at all. Please call me here at the shop or on my cell phone that I am going to pm you. I will help you or take them back for a full refund which ever way you would like. Sorry I didn't see this sooner.
Randy
763-477-9272
Sep 19, 2006 | 05:48 PM
I don't ave DRM coil overs but I run against cars that do and they do work great. Randy will get it right for you.
