04 ZO6 Diff vs 02 Coupe M6 Diff?
Sep 17, 2006 | 10:23 PM
I remembered seeing some one post that the ZO6 had a hardened diff and the coupe M6 is not hardened. I know they are both 3:42 but can anyone tell me if they ARE ACTUALLY DIFFERENT? Thank you in advance.
Sep 17, 2006 | 10:25 PM
sorry for the double posting, moderators please delete. Thanks!
Sep 18, 2006 | 12:40 AM
St. Jude Donor '08
Only difference is one has shotpeened gears and the other does not.
Z06 rear has the shotpeened gears (i.e. a little stronger gears) nothing else different.
Sep 18, 2006 | 03:50 AM
Sep 18, 2006 | 07:06 AM
also. You may notice a slightly lower rpm in 6th gear @ 80mph cruise with the M6.
Sep 18, 2006 | 08:27 AM
Thanks, if given the choice, is it worth it to do a swap between the two if I'm putting down 650RWHP? Would it be safer?
Sep 18, 2006 | 08:47 AM
Cruise-In VII Veteran
Quote:
Tony covered the sp gears
, Safer? no, the next step would be swapping in a diff from DTE and adding a trans brace, I've seen a couple cars at the track snap output shafts
Sep 18, 2006 | 10:28 PM
I did double this thread by accident, sorry! Thanks for all your input...
Sep 18, 2006 | 10:33 PM
standard 3.42 carrier GM #12551769
Z06 3.42 carrier GM #12572683
Sep 18, 2006 | 10:55 PM
and...the GETRAG tag should indicate 3.42SP (for shot peened).
Sep 19, 2006 | 05:50 AM
Confirm this with DTE but I also believe that in 04 they strengthened the case. Their web site states that only 04 cases will be used for their Stage V differential due to a third rib being added.
