How far to push front spring when lowering?
Old Sep 19, 2006 | 11:17 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Default How far to push front spring when lowering?
I tried to do the lowering procedure, but was unable to move the 10mm studs. I pressed up on the spring about a half inch, but was afraid to push any more than that. This was done about a foot away from the joint. Does anyone know how far I can go with the spring without damaging it?
Old Sep 20, 2006 | 12:38 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
If you are seeing noticeable deflection, I think you've gone far enough. You might have better results by using a jack with a smaller surface area that will allow you to tuck into the A-arm, closer to the bolt. In any event, make sure you are outboard of the spring shackle (as below).
Old Sep 20, 2006 | 07:02 AM
vettenuts's Avatar
vettenuts
Bolt may be froze, have you tried any penetrating fluid? Don't get it on the composite spring though.
Old Sep 20, 2006 | 03:04 PM
$$$frumnuttin'
thanks for the tips. I did add regular motor oil to the threads, but very small amount. Penetrating oil contains solvents which could affect the plastic in the spring. I'll give it another try.
Old Sep 20, 2006 | 03:29 PM
vettenuts's Avatar
vettenuts
Use a six point wrench too
Old Sep 20, 2006 | 04:15 PM
Rhode Warrior's Avatar
Rhode Warrior
Mine was tough.
To How far to push front spring when lowering?
