How does speedo work?
Old Sep 20, 2006 | 02:40 AM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
Default How does speedo work?
I have changed my rear axle ratio to 3.90 and my tires have been changed to front 275/35/18, rear 305/35/18.
Depending where the speedo picks up its data maybe my speedo is off.
Where does speedo get data?
Can a tech II change any of the parameters used to determine speed? i.e. correct for above changes.
I have a '97 mn6 coupe.
Thank you
Roy
Old Sep 20, 2006 | 03:17 AM
ZeeOSix's Avatar
ZeeOSix
Not sure where it picks off the speed, but if it's somewhere in the drive line your speedo will be off due to the diff gearing change and tires. If it picked it up at say the rear axle (doubt it) then changing the gearing wouldn't change the speedo if the tires were still OEM size. Humm ... sounds like a good way to do it. That or maybe a pitot tube.
Old Sep 20, 2006 | 05:36 AM
Rhode Warrior's Avatar
Rhode Warrior
Not sure where it picks up it's signal, but you only need to have your gear ratio changed on the cars computer. I went from 2.73's to 3.42's and not only would the speedometer have been off, but being that my car is an automatic, my shift points would have been too high. Any tuner who works on Vettes can do the change for you, only takes about 10 minutes, then a quick road test.
Old Sep 20, 2006 | 07:16 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Changing rear end ratios will not affect speedo & odometer readings. But, changing tire sizes (diameter) will...
Old Sep 20, 2006 | 10:01 AM
Varmit's Avatar
Varmit
St. Jude Donor '08
Old Sep 20, 2006 | 10:04 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
The electronic pickup for road speed sits in the differential.
Old Sep 20, 2006 | 11:43 AM
robvuk's Avatar
robvuk
Why would your shift points change???? 6000rpm is 6000rpm no matter what gear is in the car.
Old Sep 20, 2006 | 12:37 PM
Mike Mercury's Avatar
Mike Mercury
Because on the A4, WOT shifting must meet RPM and MPH thresholds.
Ths speedo gets pulses from a reluctor wheel attached to one of the output shafts inside the carrier (diff). Rear axle ratio changes will not alter the speedo accuracy on a C5... period - end of story.
But rear tire heigth changes will
Old Sep 20, 2006 | 01:23 PM
ZeeOSix's Avatar
ZeeOSix
So it must pick-up the axle rotational speed?
Old Sep 20, 2006 | 02:23 PM
robvuk's Avatar
robvuk
That's interesting. Any particular reason why they would make it that way? I never heard of such a thing. I knew that throttle position is included but not mph.
Old Sep 20, 2006 | 07:46 PM
Dan_the_C5_Man
Yes.
Old Sep 20, 2006 | 11:56 PM
7.0sc SuperVette
Default Thanks forum members...
It seems like the output shaft pick up is it.
So I can simply prorate my mileage by the ratio of new tire height by original tire height.
Looks like a wrap-thanks again guys!
Roy
Old Sep 21, 2006 | 12:35 AM
Dan_the_C5_Man
Roy
Indeed you can alter the multiplier to correct for differences in rear tire diameter.
An interesting point; when I swapped out my standard C5 tires for Z06 sizes (approx. 5% reduction in rolling diameter), I contemplated changing the multiplier to compensate. But when I looked at the numbers, backed up by tachymeter measurements with mile markers, the change from stock to Z06 sizes brought the accuracy of the speedo perfectly in-line, that is 60 MPH on the road registered as exactly 60 MPH on the display. The reason this occurs is by default the factories (all of them) bias the speedometer calibration on the high-side, so as to avoid liabilities / litigation. So ultimately I decided to leave the stock values in place, comfortable in the knowledge I have a highly accurate speedometer calibration.: cheers:
To How does speedo work?
