Ok thats what I needed to know He is trying to order some more tires today and needed to know what to get. Thanks you again for all the help
does this also apply to the C4 ?
No. They must be staggered, that is why you can not rotate tires on a corvette.
Not true. They can be the same diameter. I ran my 97 and now my 03Z for several hundred miles on several weekends each year with the same diameter tires (25.3 inches) front and rear.
Haven't heard of anyone but road racers doing this and they turn off AH.
I have run with and without AH. I use 17 x 9.5 wheels in the front and 17 x 11 in the rear. Tires are 275/40 in front and 315/35 in the rear. Tire diameter front and rear is 25.3 (mfg's spec). The TC may trigger a little more quickly when spinning the rear wheels but that isn't a problem since we turn off TC when autocrossing or running around a track.
Originally Posted by netguru
How do you turn off active handling? I was only able to turn off traction control to make it drivable.
Your car may not have Active Handling. 97s did not have AH and it was optional through 2000. If you have it you will have a JL4 option code listed in your list of options on the glove compartment door or the rear left storage compartment lid.
Bill
All C5's were not created equal. Some earlier models did not have AH as it was an option. It was not until 2001 that it became standard on the C5.
You can check vehicle if equipped "JL4". Manufacturing codes are in glove box or in rear cubby holes depending on date of manufacture.
If you have AH. Press and hold the button on the center console (have all door closed) and you will get message that you're turning off traction and AH, hold it for a couple more seconds and it will go into competive mode.
