How can I do this?
Old Sep 23, 2006 | 01:23 PM
ROD BROWN's Avatar
ROD BROWN
Default How can I do this?
I would like to remove the battery cables from the battery to clean the cables without loosing all my settings.Can anybody guide me in the right direction.Thanks
Old Sep 23, 2006 | 04:45 PM
SLPRC5's Avatar
SLPRC5
Radio Shack has a 9v cig adapter that you plug in the cig lighter and it retains the memory.
Old Sep 23, 2006 | 06:09 PM
LoneStarFRC's Avatar
LoneStarFRC
From what I've seen and heard from various vendors (that sell that little item) is that they either do not work on the C5s or are otherwise not recommended.
Maybe someone else can chime in.
Old Sep 23, 2006 | 07:47 PM
hotwheels57's Avatar
hotwheels57
I'll chime in...I've had one of those little ditties for several years and they've always worked for me...unless you're trying to save the memory overnight. The 9V battery will not last that long. I recently suggested to someone to check RADIO SHACK and he PMed me saying RADIO SHACK told him they don't carry them (that's where I got mine)...you might try PEPBOYS, AUTOZONE, CHECKER or your favorite dittie source. It should cost you less than $10.00 not including the 9v battery. You can probably find one at WALMART or TARGET. Do an internet search under "cigarette lighter memory saver" and you'll find reference to them. They look like this...
FYI: Someone is also making a 110v dittie that also plugs into the cigarette lighter which would last longer.
Old Sep 23, 2006 | 08:21 PM
bob guzzy's Avatar
bob guzzy
Default battery
Why not use a couple aligator clips and two pieces of wire, or a portable starter box, just clamp it to the outside of the cables, just be a little carful, removing and replacing cables...B
Old Sep 23, 2006 | 08:35 PM
SLPRC5's Avatar
SLPRC5
take hotwheels57 advice and do a search at the mentioned stores. MidAmerica has them for '99 up I believe. Also at the looks of the one pictured you can make your own
Old Sep 27, 2006 | 10:38 PM
Brad@RevXtremeAutoSports's Avatar
Old Sep 28, 2006 | 01:45 PM
bighank's Avatar
bighank
Default battery cables
Taken mine off a dozen or so times. If you are quick lose NOTHING.
otherwise might have to reset the radio. Not a biggie unless you don't like to push and hold the buttons. My key fob resynched just by holding the open and lock buttons down simultaneously for about 8 or 10 seconds. Never lost tire pressure monitors with a battery off.
To How can I do this?
