Texaco with Techron
Old Sep 24, 2006 | 04:37 PM
BubblePuppy's Avatar
BubblePuppy
From: Si Vis Pacem Habeatis Filios Vestros, Ad Bellum Parare Modo
Default Texaco with Techron
Noticed for the first time that the local Texaco station states that it contains Techron. Is this the same (Chevron) Techron that we put in our fuel tank to keep the system clean? I've been using Shell V-Power, but would be willing to switch if the Texaco is better. Anyone like to share their opinion on this?
Old Sep 24, 2006 | 04:45 PM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
Yep, Chevron and Texaco merged back in 2001. I don't know if Shell is better than Chevron or Texaco but they are all top tier gasoline. Check out the top tier gasoline companies here
Old Sep 24, 2006 | 05:03 PM
cruisemon's Avatar
cruisemon
Same compound and it works. If you think you have dirty injectors, run the Texaco for 3 or 4 tanks and you'll see a difference if they were dirty. You can also buy Techron at Costco for $9.99 for 4 bottles to treat 16 gallons per bottle. That works out to a little over 15 cents a gallon. If you can buy another gasoline for more than 15 cents less than the Texaco, this is the way to go. Otherwise, run the Texaco or Chevron depending on which is available.
Charlie
Old Sep 24, 2006 | 07:38 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Originally Posted by cruisemon
Same compound and it works. If you think you have dirty injectors, run the Texaco for 3 or 4 tanks and you'll see a difference if they were dirty. You can also buy Techron at Costco for $9.99 for 4 bottles to treat 16 gallons per bottle. That works out to a little over 15 cents a gallon. I you can buy another gasoline for more than 15 cents less than the Texaco, this is the way to go. Otherwise, run the Texaco or Chevron depending on which is available.
Charlie
Plus, you won't have the fluctuating gas guage readings.
Old Sep 24, 2006 | 09:03 PM
cruisemon's Avatar
cruisemon
That's another benefit as well.
Charlie
Old Sep 24, 2006 | 09:11 PM
MUKAK's Avatar
MUKAK
To Texaco with Techron
