Is this called "run-on"?
Old Sep 25, 2006 | 02:57 PM
jostrichm's Avatar
jostrichm
Default Is this called "run-on"?
Sometimes after I shut the car off it still turns over a couple times after the ignition is off...maybe for a second at the most. Could that be a timing deal or is it normal?
Old Sep 25, 2006 | 03:04 PM
IrishJoker's Avatar
IrishJoker
That's called "dieseling" or engine run on. Could be a timing issue - throwing any codes?
Old Sep 25, 2006 | 05:04 PM
patton's Avatar
patton
St. Jude Donor '09
normal ? yer kidding what is the idle rpm
Old Sep 25, 2006 | 05:47 PM
suicide king's Avatar
suicide king
Is it an automatic or manual trans?
If it’s manual and you don’t hold the clutch in when you turn it off it could shake, make a noise or sound like a motor run on.
If it’s an automatic and the motors turning after it’s shut off use a higher grade gas or check to see if you’re getting any codes.
Good luck
Old Sep 26, 2006 | 10:13 AM
No, not normal. Sounds like something is out of adjustment.
Old Sep 26, 2006 | 12:35 PM
Flat Broke's Avatar
Flat Broke
Timing or wrong fuel being used may cause it also.
Old Sep 26, 2006 | 02:16 PM
95BlueBomber's Avatar
95BlueBomber
Default More detail pleas
Maybe a few more details on the car could help us diagnose your problem. If it is a six speed I would lean towards the Drivetrain noise they all make after turn-off. It sounds like turning over but a little more high pitched. I am guessing its "gear rattle" from the drivetrain. If you are concerned have a compression test and leak down done on the car. "dieseling" can occur because of compression loss, but again I am saying gear rattle.
Old Sep 26, 2006 | 03:35 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Good luck
Old Sep 26, 2006 | 04:15 PM
jrose7004's Avatar
jrose7004
Absolutely not normal!
Old Sep 26, 2006 | 04:40 PM
Ron Dittmer's Avatar
Ron Dittmer
It's not right. Start diagnosis using premium fuel for a hundred miles, and go from there.
To Is this called "run-on"?
