Clutch Recommendation Needed
. What would you guys recommend I replace the stock with? We're looking at 500 hp max, with visits to the drag strip once or twice a year. I do not want expensive overkill, or a clutch that makes the car harder to drive (wife's car). Just something that will hold the existing HP. What would you recommend?
Clayton from Las Vegas
17lb steel flywheel with ceramic clutch disk. Hardly any chatter at all but it holds like a mother and the pedal is as light as the stocker.
Which one is the "official" textralia and which one is $115?
I have a Tex and can say it is a great clutch and drives almost stock like, but grabs like hell when you want it to. It can also be slipped out of the hole unlike many other aftermarket clutches that are on/off.
It holds awsome, there are 5 around here that are using it. One is a cammed ls1 with a 150 shot and pulls low 1.6 60's. No problems at all. Bought mine with a brand new LUK pressure plate for $250 shipped. I also bought a 17lb lightened flysheel with SFI certification for $135. As for customer service, I will guarentee if you call the people that sell this one you will get a person the first ring and if you want you can talk to the owner of the company and he will answer all your questions. Too bad most of these forums shut down anything that serfaces about these clutches because they don't advertise on these boards.... It is freaking ridiculous that there can't be a car community without being ruled by PAID sponsors....
You know, parts for a LS1 really don't cost more to make than anything other part, it is simply marketing that keeps these prices high.
Believe me I cringed when I dropped a grand for the Tex, but after all is said and done Im completely happy with the purchase.
If I was running DR's or spent a lot of time on the drag strip then I would be looking at the OZ700, but for street tires I do not belive you will have a problem.
More Than Zero
Ok, so you have 6 puck disc that looks similar that doesn't mean it is the same.
We have a Textralia in Tommy's car. It holds fine behind 503 RWHP.
lol, we have compared them side by side. You can not visually tell a difference. ESPECIALLY in that pic, if so get a new monitor.
The rivets are those shiny silver things in the middle of the pucks...
There was a side by side picture posted of both discs.
I'll post both pics together so you can see the difference.
If you look closely you'll see that the pucks are the same in shape, but are a different color. You'll also notice the edge around the puck is a more copper color. In additon, you'll notice the rivets are alternating on the picture from BYUN, and the other one the rivets are in the same side. You'll also notice the center hub is set up differently.
IMHO, This would indicate most likely a different puck material being used , and that it not assembled by the same group of people.
I'm not saying what you pieced together isn't working for you. But folks try to assume its a certain vendor. People have made all sorts of assumptions saying there is some huge markup, and everyone is being ripped off. In the ad for those discs, it says the discs were being sold at the distributors cost, not what they sold it to the end user for.
The bottom one is a textralia. I got it off byunspeeds website. The one I have is excatally like a textralia. I have seen a real one and this one side by side.
