Changing spark plugs
Old Oct 4, 2006 | 09:48 PM
doug b's Avatar
doug b
Default Changing spark plugs
Has anyone attempted to replace all 8 spark plugs on 1998 C5 / LS-1? If so, were there any major difficulties? What tools were needed?
Old Oct 4, 2006 | 09:58 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
It's not that difficult.
The only tool that I would recc. is a double swivel spark plug socket. It makes gettting to the rear most plugs a bit easier.
Old Oct 4, 2006 | 10:26 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
The basics....
Buy a tube of antiseize
Don't over torque the plugs and make sure they aren't cross-threaded
Don't pull the plugs on a hot engine
Pull the plug wires by the boots, not the wire.
Finally, buy a box of bandaids...you'll need them.
Old Oct 5, 2006 | 12:44 AM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
It really is not that bad of a job.
The aft drivers side plug (#7?) was the one I dreaded. I had read a lot about how much trouble people had. In the end, it was not that bad at all.
I took off the coil packs to give me a little extra room and to clean things up a bit.
I went with the MSD red wire set, P/N: 32819 and the NGK TR55 plugs.
Click for a little bigger picture.
Old Oct 5, 2006 | 01:58 AM
franny40's Avatar
franny40
i changed them out in less than an hour, not bad, but my f body is a different matter
Old Oct 5, 2006 | 05:44 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
#7 is the only one that's a little tricky, but overall, it's not a big deal.
(this being said, of course, by someone who has changed the plugs in a currently owned LT-1 engined Camaro, and also owned in the past, and changed the plugs in a big block powered '71 Chevelle....then again, that #7 plug in the '68 Chrysler with the 440 was NO picnic either)
Old Oct 5, 2006 | 07:25 AM
VetteTech81's Avatar
VetteTech81
Exactly pass side is a breeze the drivers side is a little more work, just take your time, use the proper tools, and as someone said don't over torque the plugs..
Good Luck!
-=Rick
Old Oct 5, 2006 | 07:20 PM
cruisemon's Avatar
cruisemon
Pick up a spark plug boot puller (looks sort of like pliers)
Pick up a universal joint for your socket wrench to give you some angle on #7 plug.
Do this on a cold engine for a bunch of reasons, mainly to avoid stripping threads in the head or buggering up your hands and arms when the plug finally releases from the pressure of the expanded aluminum (hot vs cold torque difference to remove is substantial). Plus if the engine is hot, you'll burn yourself
Be careful with gapping the platinum and iridium plugs. It isn't hard to bugger the electrodes
Don't even think about putting the plugs back without anit seize
Check to be sure, but I think the install torque is maybe 12 ft lbs or something. I don't have my manual handy and I've slept since I last looked at the spec.
Take your time and have fun. By the way, if you have a Harbor Freight nearby, the plug wire puller, universal, etc., are quite reasonably priced. It might be argued that other brands have higher quality, and if I were going to change plugs for a living or more often than every 100,000 miles, that might be a factor. Watch for sales on both. I picked up my pliers for about $4.00 on sale.
Charlie
Old Oct 5, 2006 | 11:29 PM
z06inVB's Avatar
z06inVB
Here is an old trick I learned on the old VW Beetles. If you can do plugs in those you can do them in anything. On the number 7 plug I slip a piece of vac. line over the tip of the plug to start it in. I did not like the idea of starting the thing with the socket and universal. This way I had a good feel for what was going on...then when it was in just pull the vac. line off and tighten her up! Not likely to cross thread it that way
Old Oct 6, 2006 | 04:25 AM
randy814u's Avatar
randy814u
Good tip, Thanks
Old Oct 6, 2006 | 12:33 PM
bighank's Avatar
bighank
Default antisieze
What kind of antisieze are you talking about? Have changed plugs for about 40 years and never used that before.
BIGHANK
Old Oct 6, 2006 | 12:39 PM
cruisemon's Avatar
cruisemon
BIGHANK
It is an aluminum powder suspended in probably a silicone oil and available at any auto parts store. The steel spark plug body and aluminum head set up a galvanic couple that not only creates corrosion but can actually cause metal bonding. The anti seize keeps the plug from being frozen in the head and stripping threads when the plug is muscled out. It is an EXTREMELY good idea and very important to use either a thread sealer or anti seize on any bolt or fastener that goes into any aluminum part on your engine for the same reason.
Charlie
Old Oct 6, 2006 | 04:25 PM
The Big Guy's Avatar
The Big Guy
St. Jude Donor '12-'13-'14
Sorry but I say to change out 8 plugs in a LS - 1 in less than 1 hour is virtually IMPOSSIBLE ! I have the proper tools and experience and it takes considerably longer ! That's my 2 cts.
Old Oct 6, 2006 | 04:39 PM
cruisemon's Avatar
cruisemon
WHEW! I wasn't going to say anything for fear of embarrassing myself but this is a 4 beer job, maybe even a six pack.
I am in awe of those who can do this in an hour. Number 7 plug took nearly half that for take out/replace with a cold engine. An hour averages out to 7 1/2 minutes per plug and I cussed #7 longer than that.
Charlie
Old Oct 6, 2006 | 04:47 PM
z06inVB's Avatar
z06inVB
Since I am new to these cars I didnt know they were hard to remove. I easily did the LS 6 in the Vette in under an hour. Number 7 was at most a 10 minute operation. I used a swivel deep well socket and an 18 inch extension and it slipped on and came right out. I used the vac. hose trick to get it threaded in and then tightened it. The only thing I did was kill two plug wires but I replaced mine with an autolite set for 34 bucks.
Old Oct 6, 2006 | 04:51 PM
cruisemon's Avatar
cruisemon
Wonder if the beer has something to do with my plug swap time.
Charlie
Old Oct 6, 2006 | 05:49 PM
Jiver67's Avatar
Jiver67
Make sure and torque the spark plugs to ~ 11 ft. pounds - you don't need to apply more torque than this with aluminum heads.
To Changing spark plugs
Old Oct 6, 2006 | 06:33 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Don't worry about torque... go finger tight + 1/16th turn or so... it's easy. Use a dab of anit-seize.
I start the ones I can by hand... and others in my spark plug socket w/ an extension... I just be very careful and don't apply any forward pressure until I know the threads have started properly.
Old Oct 6, 2006 | 06:49 PM
JR_VETTE's Avatar
JR_VETTE
It is with headers.
Old Oct 8, 2006 | 05:36 PM
aquachuck1's Avatar
aquachuck1
Pull the rubber vacuum line out of the power assist unit on the firewall beside #7....bend it out of the way....use a short handle 3/8 rachet and a short extension with the spark plug wrench on it....no problem had it out in minutes. If you value your hands buy some mechanic's gloves when changing the plugs.
