cam install tool question
Old Oct 6, 2006 | 09:31 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Default cam install tool question
I was told that I can use 2 5/16 rods rather than buying the tool. I noticed the tool has a flat side along the rods. Is the flat side a must or can I just use the regular rods? Thanks........Marc
Old Oct 6, 2006 | 10:15 AM
cam99's Avatar
cam99
Use magnets instead, use the good ones, though.
I found some at Sears.
I Think you may need the flat on at one of the rods, maybe one of the guys that used it can chime in.
Old Oct 6, 2006 | 10:47 AM
msghuff's Avatar
msghuff
Ive done at least 10 cam swaps on lsx vehicles. Each time I used wooden dowels bought from lowes. Just make sure you spin the cam by hand hard right before you pull it out and you will be fine. I normally spin it then drop 16 flex straws in the pushrod holes and observe it for a few minutes to see if they move. Then spin it one more time before pulling it out. I always have the other cam ready to drop in also....No issues so far
Old Oct 6, 2006 | 07:38 PM
mvvette97's Avatar
mvvette97
i bought some 5/16 rods but I have heard that you have to grind them down. What part do you grind down? I noticed on the cam tool you buy from TR has one side ground flat along the rod, do I have to grind it that way?
Old Oct 6, 2006 | 08:58 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
the pass. side seems to be the tighter fit
Old Oct 7, 2006 | 01:19 AM
keliente's Avatar
keliente
You don't have to grind the rods. I spun the cam hard, inserted the dowels, pulled old cam out and installed the new cam.
Old Oct 7, 2006 | 01:23 AM
mvvette97's Avatar
mvvette97
I assume that you had the 5/16 rods?
To cam install tool question
