Techron users
Old Oct 9, 2006 | 04:19 PM
Sonny71's Avatar
Sonny71
Oldtimer
Default Techron users
I still have the dreaded "Low Fuel level" appearing on the DIC and the analog gauge is reading empty again. There is over 1/2 a tank right now. Question is how often can I add Techron before I run into other problems, right now it's been every other tankful.
Old Oct 9, 2006 | 04:25 PM
Vassili's Avatar
Vassili
Thats it....
Old Oct 9, 2006 | 05:02 PM
craig04c5's Avatar
craig04c5
To much of a good thing is bad. Techron is a corrosive and should only be use at 3-5K intervals.
Old Oct 9, 2006 | 05:04 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Any Chevron or Texaco gas staions in your area. Both have Techron in the fuel.
Old Oct 9, 2006 | 05:32 PM
Sonny71's Avatar
Sonny71
Oldtimer
Shell is the only one that's close and the last two tanks have been Shell
Old Oct 9, 2006 | 06:50 PM
brucemoose2's Avatar
brucemoose2
My car had that problem when I bought it. I brought it back to WA and use Chevron, exclusively. Never had that problem, again.
I used to live in CT and NY and I think I remember seeing quite a few Texaco stations... at least there was one near my house in CT.
Have you tried Mobil gas? I know you can find that in NY and that stuff never caused me any trouble in my other cars.
Old Oct 9, 2006 | 07:33 PM
Sonny71's Avatar
Sonny71
Oldtimer
Mobil/Exxon are all over around here but they do not appear on the top tier gas lists that I have seen. I've always used Mobil in my 71 and 67 with no problems, but they had 4bbls or tripower and you couldn't beat their sending units with a hammer. Modern technology is getting to me I guess.
Thanks for your thoughts,
Sonny
Old Oct 9, 2006 | 09:40 PM
cruisemon's Avatar
cruisemon
Chevron and Texaco fuels contain Techron. How would I reconcile running these fuels containing Techron with its corrosive properties all the time? Has Chevron or Texaco put out something suggesting limited use of their fuels that contain Techron?
Charlie
Old Oct 9, 2006 | 09:47 PM
TEXHAWK0's Avatar
TEXHAWK0
Charlie
Are you kidding?? No petroleum company is going to tell you not to use their gas exclusively.
On the other hand, I think they have to provide fuel with additives at a level that they will not create more problems than they solve.
I don't think you will have any long term problems using Chevron gas with the concentrations of Techron found in the gas. GM even uses Chevron gas as the standard for testing Corvettes. All fuels have some additives, and Techron is among the best for avoiding fuel system problems.
Old Oct 9, 2006 | 10:17 PM
brucemoose2
Originally Posted by TEXHAWK0
Are you kidding??
Uhh yeah, I think he was.
Old Oct 9, 2006 | 10:25 PM
cruisemon's Avatar
cruisemon
Busted.
Charlie
Old Oct 10, 2006 | 01:30 AM
vizette's Avatar
vizette
Different things have worked for different people from what i've read. I couldn't get anywhere with Techron or BG44K or any other additives. The only thing that worked for me was Shell V Power.
Good luck!
-Rich
Old Oct 10, 2006 | 01:39 AM
briann510's Avatar
briann510
My 03 with 27K has seen nothing BUT chevron gas in it since new with no problems.
Old Oct 10, 2006 | 09:27 AM
TEXHAWK0's Avatar
TEXHAWK0
Busted.
Charlie
I should have known...
Old Oct 10, 2006 | 09:56 AM
mfrejek's Avatar
mfrejek
Where can I read more about techron being corrosive? I can't seem to find anything to support that.
http://www.chevron.com/products/prod...ate_plus.shtml
Old Oct 10, 2006 | 11:56 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Eventually, if Techron can't clear up the problem, you'll have to replace the sending units. That's what I had to do. And thank heaven for GMPP.
Old Oct 10, 2006 | 12:55 PM
Blow Torch's Avatar
Blow Torch
There's your problem...
I experieced the "fuel gauge problem" when I first bought my car, but have not had a problem for close to two years. Before a trip to Florida about a month ago, I filled my tank at the Shell station close to my place of employment. (My tank was completely MT) The "drop to MT" problem happened 3 times on the trip!!
Upon returning, I went back to using Exxon or Chevron as I always have. I just returned from a 900 mile trip, and I didn't have a single occurance.
To Techron users
Old Oct 10, 2006 | 02:31 PM
craig04c5's Avatar
craig04c5
I saw it on MotorWeek on pat Goss's garage segment. I just checked the side of a bottle and it says it contains "stoddard solvent" so it makes sense.
Old Oct 10, 2006 | 06:26 PM
ersatz928's Avatar
ersatz928
Techron is not corrosive, but extended use of high concentrations will contaminate the engine oil (from normal ring blowby), which reduces its lubrication performance. The amount of Techron in Chevron gas is not high enough to be a concern, but the concentrate in the bottle is a high dose.
It took about 4 bottles of Techron concentrate to clear-up my fuel level sensor issue in my 01.
Old Oct 10, 2006 | 06:28 PM
corvette Mark's Avatar
corvette Mark
Shell gas messed up my gas gauge. Cheveron gas fixed it.
