Turkey baster and brake fluid
Old Oct 12, 2006 | 06:49 AM
jmliles's Avatar
jmliles
Default Turkey baster and brake fluid
I've heard of a lot of people using the turkey baster method solely (no bleeding) to change clutch and power steering fluids because the systems don't hold much fluid in the first place.
However, I also heard about several people using this same method to change brake fluid--with no bleeding afterwards. I can't imagine the fluid in the lines cycles around enough for this to be effective. Or does it? Could this method effectively clean up the entire system over a period of frequent reservoir cleanings?
Old Oct 12, 2006 | 07:08 AM
JCR's Avatar
JCR
Changing the storage tank (master cylinder) doesn't remove what's in the lines or the caliper. They are dead ends.You have to flush the lines as well.
Old Oct 12, 2006 | 07:12 AM
AU N EGL's Avatar
AU N EGL
Turkey baster or a 50cc surange, to mix gas and oil for a 2 cycle eninge in the lawn and garden part of home depot
put on 3 or 4 inchs of tygon tubing.
Suck out the old brake fluid of the MC and replace with new fluid. Still must bleed each caliper. Watch the MC fluid level and add as needed.
Old Oct 12, 2006 | 07:19 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I did it and thought it helped some. It was easy enough to try
Old Oct 12, 2006 | 08:12 AM
djengr's Avatar
djengr
My 2 cents. When I change brake pads on any car, I bleed a bit expanding the calipers. Once new pads are on I always bleed the brake lines a little and add fresh fluid to the reservoir. I have not had to do this on the vette, but I would follow that procedure when I do.
Old Oct 12, 2006 | 09:26 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
you would have to bleed the lines for it to be 100% effective.
Old Oct 19, 2006 | 02:57 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default bleeding
bleeding and flushing are not the same.
bleeding gets out air, flushing does the same, except to flush you can go through a gallon of fluid b 4 the lines are clear
you knew that already
To Turkey baster and brake fluid
