Start Up Problems... help!
Old Oct 15, 2006 | 11:58 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
Default Start Up Problems... help!
I finished installing my motor this weekend. went to start it up, nothin, just a clicking sound from the starter. im pretty sure i hooked it up the way it suppose to be. but why is it not starting. Also, the positive battery cable got REAL hot and started slightly smoking. the ground wire was also a lil warm, but the red one was sizzling hot! what does this mean???
so im thinkin, maybe the wires on the starter are not correct?
or a wire is touching the headers and grounding itself to the chassis.
anyone have any thoughts on this... all would be appreciated!
Aj
Old Oct 16, 2006 | 12:29 AM
Corvette4ever's Avatar
Corvette4ever
Are there any error codes in the PCM?
Old Oct 16, 2006 | 12:47 PM
muncie21's Avatar
muncie21
The warm wires could either be from a loose connection or pulling too much amperage. Although, typically the ground wire is the one that gets fried if you pull alot of amps. Maybe your wires are reversed....
Old Oct 16, 2006 | 02:24 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
thanks guys...will look at the wires on the starter, i have a feeling they are reversed...
Aj
Old Oct 16, 2006 | 02:31 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Old Oct 16, 2006 | 03:16 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You probably have the wires reversed or you are grounded out some how.
Old Oct 16, 2006 | 04:23 PM
SmoothFRC's Avatar
SmoothFRC
maybe a short in the starter? You can try hitting the starter with a battery charger to see if it will spin (off the car of course)
Old Oct 16, 2006 | 05:20 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
well guys, the car is being towed off to DRM tommorow, Doug will take care of it.
I am getting very excited!!! He should have the car done by this week! tuned and ready to roll..i havn't driven the car more then 2500 miles this whole summer... i got abotu 3 weeks or so to drive her till i have to put it away for winter... ohh well...
thanks again guys, appreciate all the feedback! i can always count on ya'll!!!
Aj
Old Oct 16, 2006 | 05:51 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Good luck with the finishing of the project and my thought was the started was crossed wired and I guess not since you are towing it in to the shop
Old Oct 16, 2006 | 09:06 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default battery
If you reversed the wires on the starter, that can be very bad.
one time I had a battery that didn't have any + or- markings in the plastic.
my wife accidentally left the interior lights on, and the battery ran down.
She called AAA and they came out to jump her battery, and didn't pay attention. He reversed the jumper cables to try to start it.
1. he blew the fusible links at the starter.
2. the battery was dead, and started to charge up backwards, only got to 5 volts when it spewed.
3. the fuel pump was running backwards
4. the alternator blew the 5th diode that keeps your battery from discharging when the key is off. had to put in a rebuild kit
5. The starter was turning backwards for a short time, and chipped the starter brushes and arced the commutator so I had to replace it.
6. the fuses blew for the dash, dash lights, mileage computer, and the receiver for the key fob.
7. The abs computer worked for about 3 weeks then failed.
so be careful when you mess with positive and negative
Old Oct 17, 2006 | 10:53 AM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
CoupeGuy: HOLY CRAP... i hope i didn't blow all that! all my dash stuff works fine soo far.. i have power to everything... we'll see.. DRM will finish it up. its getting towed today to him! Can't wait...
Aj
To Start Up Problems... help!
