Oil Consumption?
Old Oct 25, 2006 | 02:33 PM
SLPRC5's Avatar
SLPRC5
Default Oil Consumption?
After having a set of 2002 LS6 heads, LS6 cam and FAST intake installed on my '97 C5 with 62K on the clock that never used oil before is now using oil not much, but I noticed on the dip stick it being below the full mark.
Also, can the dip stick reading be inaccurate by it being move away from the block when headers were put on?
Is this normal; or do I have to go to a catch can?
Thanks,
SC5
Old Oct 25, 2006 | 03:13 PM
SLPRC5's Avatar
SLPRC5
ttt
Old Oct 25, 2006 | 05:12 PM
Dirty Howie's Avatar
Dirty Howie
You have to get a catch can like the rest of us !!!!!
There are plenty of posts on this....let me know if you want my input.
DH
Old Oct 25, 2006 | 05:47 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Hey deno, when you had the heads put on did they put new valve seals on? My TA used oil but after the cam swap and new valve seals it hasn't used any
Old Oct 25, 2006 | 08:02 PM
SLPRC5's Avatar
SLPRC5
Hey Marc..the engine that the heads came off of had 10K on them. I don't see the tell tale smoke from valve stem seals upon acceleration after sitting for awhile. I'll have the installer replace them while he is doing the rockers. But Dirty Howie may be correct about the "catch can". I hate the thought of placing one on the engine, because I feel the engine should have been designed better for the price paid for a Corvette. But we do what we got to do.
Old Oct 25, 2006 | 08:05 PM
SLPRC5's Avatar
SLPRC5
DH
hate the thought of putting a catch can on it. You would think they would have had a better design for a Corvette.
Yes DH I need your input BTW I thought the problem was fixed on starting in 2001. My heads came of a 2002 ZO6..Thanks
Old Oct 25, 2006 | 09:00 PM
Dirty Howie
I have the AMW can but I think the Elite can is virtually the same thing and they are a CF vendor.
By using disposable feul filter I found that oil was still getting by the can so I added a Campbell-housse filter as well. This is for the valley cover to intake manifold line.
I also found oil going from the valve cover to the airbridge line as I have a LS2 throttle body. Just put a fuel filter in this line to your TB if you have LS1 and see if any oil is passing there. If so you may want to add another Campbell-house filter as I have.
DH
Old Oct 25, 2006 | 09:13 PM
mvvette97's Avatar
mvvette97
I had a thought Deno, I heard on LS1 teck that you have to put loc tite or a sealer on the rocker bolts because if you don't oil will seep down the threads and down the intake runners or something like that. then it will use oil. Anybody heard this?
Old Oct 25, 2006 | 10:01 PM
SLPRC5's Avatar
SLPRC5
DH
D H..I have LS6 heads and LS6 cam on my LS1 engine. The TB is a LS6 TB. Guess this is the same as an LS1 TB. I'll check it for oil and do as you recommended, guess those fuel filter made of see thru plastic with the paper filter material would work well.
I just checked out the CC by Elite and it looks great and simple to install.
So I guess I'll go with one of Elites models.
Thanks DH
SC5
Old Oct 25, 2006 | 10:02 PM
SLPRC5's Avatar
SLPRC5
Marc that is interesting and hope to see others chime in on this...
Deno
Old Oct 25, 2006 | 11:09 PM
mvvette97's Avatar
mvvette97
Deno
yea so do I because when I done the cam swap on my TA I forgot to put any sealer on the rocker bolts
Old Oct 26, 2006 | 01:38 AM
SLPRC5's Avatar
SLPRC5
That's a bummer dude, hope you don't have a problem.
I'm thinking of putting a catch can on the PVC line and a see thru glass fuel filter on the vacuum line from the valve cover to the TB in case there is any blow by oil going to the TB.
Old Oct 26, 2006 | 02:25 AM
mvvette97's Avatar
mvvette97
If i were you I would just either pull off the TB or just open the throttle blade and reach in and feel if there is any oil in the intake. If there is that is your problem. If it is dry then you have other problems
Old Oct 26, 2006 | 04:50 PM
SLPRC5's Avatar
SLPRC5
Thanks Marc...I'll do just that. I did notice oil on the bottom of the LS6 intake when it was removed, so that is n indication maybe that oil is going throug the TB by way of the vacuum line from the valve cover.
Old Oct 26, 2006 | 06:03 PM
SLPRC5's Avatar
SLPRC5
OK Marc... I checked and there was some oily film on the TB blade, so I placed a fuel filter in the vacuum line to see how that will work before getting a catch can.
Old Oct 26, 2006 | 07:06 PM
mvvette97's Avatar
mvvette97
That must be the problem. It didn't suck oil before did it? I had to put a catch can on my trans am because it was doing the same thing. So far the vette has been fine though.
Old Oct 26, 2006 | 08:10 PM
SLPRC5's Avatar
SLPRC5
I had no problem with oil usage prior to having the LS6 heads and cam installed. So I'll be able to keep an eye on the filter to see if it is collecting oil. You think this filter alone will work or should I install a catch can also?
To Oil Consumption?
Old Oct 26, 2006 | 08:24 PM
mvvette97's Avatar
mvvette97
You want to watch the filter because in time it will plug and then you will have restricted vacume to the block. It would almost be like not running a pcv. I would buy a catch can. I got mine for like 40 bucks from the auction site. Looks nice and it works.
Old Oct 26, 2006 | 08:37 PM
SLPRC5's Avatar
SLPRC5
I plan to watch it closely...I sent you a PM about the purchase of your catch can...
Old Oct 27, 2006 | 09:02 PM
SLPRC5's Avatar
SLPRC5
Marc here is the filter I installed today on the vacuum line to the TB.
What do you think about it curing the oil going to the TB?
