exhaust system
Old Oct 25, 2006 | 03:24 PM
plunkman's Avatar
plunkman
Default exhaust system
I just had the honker air intake installed and am thinking about modifing the exhaust system. How much h.p. can i expect to get by just putting on a system from the x pipe back ,changing the mufflers to ones that dont have the chambers, packing or the baffles of conventional ones??
Old Oct 25, 2006 | 03:30 PM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
Just doing a catback, i would guess 5hp maybe a lil more.
Old Oct 25, 2006 | 03:51 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Adding a cat back system is NOT going to give you anything earth shattering~! 5-8 is about normal but, a good free flowing exhaust system is the BASIC building block for heads/cam addition.
Old Oct 25, 2006 | 07:57 PM
plunkman's Avatar
plunkman
thanks in what direction should i go in head and cam work i.e. type , set up etc.
Old Oct 26, 2006 | 09:44 AM
99 vett babycar's Avatar
99 vett babycar
First figure out what you want from a cam and thenyou're best off doing a search on cams.
Old Oct 26, 2006 | 01:10 PM
plunkman's Avatar
plunkman
ok thanks
Old Nov 3, 2006 | 12:02 PM
Vetteoholic's Avatar
Vetteoholic
5-8 sounds about right, but get a tune as well to vastly Improve your gains. Good luck ~CHRiS~
Old Nov 3, 2006 | 02:20 PM
gja's Avatar
gja
If power is what you're after, then start looking into headers, along with the catback.
See the LG special and see if that interest you.
To exhaust system
