[Help] GM bra install! (WTF are those plug things?!?!?)
Old Sep 19, 2001 | 12:14 AM
hermiteer's Avatar
hermiteer
Default [Help] GM bra install! (WTF are those plug things?!?!?)
I feel like an idiot (especially after installing intake and exhaust myself) but I am having trouble with the GM bra install.
The bra came with 4 bolts (button head) and 4 wierd rubber plugs. The instructions, rather fuzzily and blurrily (are those words), seem to indicate removing two of the screws in each tirewell. Each hole is replaced the union of the bolt and rubber plug. The rubber does expand, per instruction manual, but seems to seperate the black plastic lining from the fender. It looks terrible and not at all like the picture. Am I missing something?
Christoph
PS. I noticed some retainer clips between the fender and liner plastic, but it does not seem right to have to remove those, especially because it would be really hard to.
[Modified by hermiteer, 10:14 PM 9/18/2001]
Old Sep 19, 2001 | 12:38 AM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
Default Re: [Help] GM bra install! (hermiteer)
I think you are on the right track. The clips that you mention must be removed from the top and bottom holes, but not the middle.
It is very hard to do and they most certainly will fall into the front of the body. I removed an additional screw that is located in further and at the bottom.
This allowed me to force my hand into the cavity there and retrieve the clips.
The black plug like pieces will expand as you tighten the screws. The expansion occurs behind the body thus providing the holding power.
Good luck I know this is a b$tch.
Chuck
Old Sep 19, 2001 | 12:43 AM
hermiteer's Avatar
hermiteer
Default Re: [Help] GM bra install! (chucschramm)
Huh. You'd think they would have mentioned that in the instructions. Alright, time to break out the needle nose pliers and a beer. Thanks for the insight.
Christoph
Old Sep 19, 2001 | 12:14 PM
Mark S.'s Avatar
Mark S.
I simply went to a Marine Hardware store and bought some screw snaps (#8) similar to the ones they provide you with for use under the front fascia and put them in. Use a little liquid detergent to help them screw in (don't remove the metal clips if you using this method). A lot easier than dealing with the rubber booties, etc. :yesnod:
[Modified by Mark S., 10:15 AM 9/19/2001]
Old Sep 19, 2001 | 12:22 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: [Help] GM bra install! (Mark S.)
:yesnod: , that's the ticket :D
Old Sep 19, 2001 | 12:43 PM
Busted Knuckle's Avatar
Busted Knuckle
Default Re: [Help] GM bra install! (Mean Green 2000)
I did the same as Mark and Mean Green.
Jim Dawes :cheers: :flag
Old Sep 19, 2001 | 01:53 PM
hermiteer's Avatar
hermiteer
Mark,
Good idea, I was wondering if that might be a possiblity. Thanks.
Old Sep 19, 2001 | 04:48 PM
Arkay's Avatar
Arkay
Trash the USELESS GM supplied screws with expansion rubber and replace
them with standard Marine screws (the same size as the fender well screw)
I used the P/N is 1039332 Stainless Screw Stud #32 x 1 inch , made by VICAR
and the box said they were Self Tapping Studs.
Call your local upholstery supply store and get the right stuff.
http://forums.corvetteforum.com/zero...ply&id=1068106
I wish someone had a fix for the flap thing that goes inside the wheel
well. Mine keeps falling out.
To [Help] GM bra install! (WTF are those plug things?!?!?)
