cam & emmissions ?help!!!
Old Oct 28, 2006 | 09:27 AM
C5VERTMAN's Avatar
C5VERTMAN
Default cam & emmissions ?help!!!
what cam should i use that will pass emmissions and still make some hp .
Old Oct 28, 2006 | 09:48 AM
7LitreC5's Avatar
7LitreC5
I have a 220/224 .581/.581 115+2 Comp cam and it passed a talepipe emissions with no problem. I did not have to employ any "tricks" to get it to pass.
Old Oct 28, 2006 | 10:01 AM
WKMCD's Avatar
WKMCD
It would help if you filled out your profile so people could give you advice based on what state you live in.
Old Oct 28, 2006 | 11:08 AM
Vette-Red's Avatar
Vette-Red
Here in Tx. a 230/227 .591/.571 on a 112lsa would pass. And our emissions are pretty tough. I think if you go with anything lower than a 112 lsa you would have probs.
Old Oct 28, 2006 | 11:34 AM
C5VERTMAN's Avatar
C5VERTMAN
in north carolina
Old Oct 29, 2006 | 05:08 AM
Switchbarrel's Avatar
Switchbarrel
Default Emissions
FWIW- LG says their G5X1e will pass a smog check
-Rick
Old Oct 29, 2006 | 09:30 PM
Billdog350's Avatar
Billdog350
If I recall, the G5X1 is 228/232 on 112 or so. That's similar to the custom cam I'm having installed shortly
If you can't pass tailpipe (Ct requires OBDII unless they suspect missing cats or your readiness isn't set) then you can try adding pure alcohol. "Air brake line antifreeze" is pure ethanol and only costs a few bucks at the auto parts store. Dump that in there with a few gallons of gas (regular or mid grade, not super) so that you're at least 20% alcohol or more...and you'll fly thru. I did that on my 1994 K1500 truck with no cat, a lumpy cam and passed with flying colors.
Old Nov 24, 2006 | 09:19 AM
gojo's Avatar
gojo
in north carolina
NC does not do tailpipe testing.
Old Nov 25, 2006 | 09:58 PM
C5VERTMAN's Avatar
C5VERTMAN
is obd II harder to pass than a sniffer ?
Old Nov 26, 2006 | 08:05 AM
gojo's Avatar
gojo
No it's not harder.
Old Nov 27, 2006 | 05:55 AM
vettenuts's Avatar
vettenuts
No because a correct tune will compensate for certain things, for instance shutting of the idle misfire detection will keep out misfire codes with a cam.
Old Nov 27, 2006 | 06:39 AM
whiteboy's Avatar
whiteboy
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
I have a More Performance H/C package producing 400+ rwhp , getting 27+ mpg on the road with 342's in an auto. Passed emissions with flying colors. More Performance is in Charlotte. Or they were , don't know if they are still in business ? I don't have the specs on the cam.
Old Nov 27, 2006 | 06:41 AM
whiteboy's Avatar
whiteboy
Cruise-In I Veteran
Indiana does both tail pipe and obdII .
Old Nov 27, 2006 | 08:45 AM
basicstrategy777's Avatar
basicstrategy777
St. Jude Donor '11-'12-'13-'14-'15-'16-'17,'20, '21,'22, '23
billdog.....can you recommend a place in your area that would give you the benefit of the doubt when it come to passing emissions.
I recently got my vette, it is not registered yet, it is modified, and I'm concerned about it passing emissions.
777
To cam & emmissions ?help!!!
