Fan Controller Wiring (Paging C5TECH, etc)
Old Sep 21, 2001 | 11:55 AM
OliverM5's Avatar
OliverM5
Active Streak: 90 Days
Default Fan Controller Wiring (Paging C5TECH, etc)
Bought a fan controller from summitt racing - It works with the ground wire - how do I attach this thing to my car - any ideas?
Old Sep 21, 2001 | 12:58 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default Re: Fan Controller Wiring (OliverM5)
I have a fan controller... it came with a thermocouple which goes between the fins of the radiator.. it has a red wire which goes to the plus side of the battery.. it has a black wire which goes to ground.... it has a yellow wire which goes to any "key on" circuit found in the underhood fuse box... it has a green wire which goes to the radiator fan.. ( Driver's side fan... blue wire).. I hope this helps
Bill ( Evil-Twin) I bought the Vinci fan controller. it came with proper length wires.. and connectors.. and mounting under the hood.....and good instructions.. took me 30 minutes to install...
Old Sep 21, 2001 | 01:15 PM
OliverM5's Avatar
OliverM5
Default Re: Fan Controller Wiring (Evil-Twin)
What is this stuff about high-speed fans, low speed, etc - which fan do I hook this up to?? Both?
Old Sep 21, 2001 | 02:08 PM
Evil-Twin's Avatar
Evil-Twin
Didn't you read my instructions??????/ I took the time to explain step by step...
[Quote] I have a fan controller... it came with a thermocouple which goes between the fins of the radiator.. it has a red wire which goes to the plus side of the battery.. it has a black wire which goes to ground.... it has a yellow wire which goes to any "key on" circuit found in the underhood fuse box.. it has a green wire which goes to the radiator fan.. ( Driver's side fan... blue wire).. I hope this helps
_______
To Fan Controller Wiring (Paging C5TECH, etc)
