FINALLY!! Headers are On!!!
Old Nov 11, 2006 | 07:55 PM
C52000C5's Avatar
C52000C5
Default FINALLY!! Headers are On!!!
Well I put the headers on today and must say that EVERYONE needs a set! This Dynatech system sounds hairy with the B&B Bullets!!! The sytem went in without any real problems (no check engine light, no torchs needed....). The only problem I have is that the end part of the exhaust is now rubbing againt the rear bumber. I may end up putting a different sytem in or just shorten the tubes. Anyone else come across this problem????
In conclusion, I would buy these again in a heartbeat! Installation was time consuming, but everything went together perfect. Thanks a lot Stu(StuandJoy)
Old Nov 11, 2006 | 10:34 PM
wayneinvirginia's Avatar
wayneinvirginia
Cruise-In VIII Veteran
I had a Dynamaxx system installed on my car this week. Great fit and I love the results. I had mine installed professionally and the installer said it was one of the best fitting systems he has ever installed. The car sounds awesome now with the Bassani aft cats. Now for a tune next Saturday and I"ll see just how accurate my seat of the pants gauge is.
Old Nov 12, 2006 | 10:08 AM
vettenuts's Avatar
vettenuts
Congrats. What you can do on the rubbing is loosen the joint to the cat back, use some pads or something and stuff them between the exhaust tips and the bumper to get them to sit correctly and then re-tighten. There is usually enought slop in this joint to move them around a bit.
Old Nov 12, 2006 | 10:55 AM
C52000C5's Avatar
C52000C5
Vettenuts, I tried loosening the cat-back but the piece's with the tips are just too far out the back. I think I have to cut them up
Old Nov 12, 2006 | 06:09 PM
Vetteoholic's Avatar
Vetteoholic
Congrats on the setup, Headers Kick *SS!!!!!!!
Old Nov 13, 2006 | 09:31 PM
C52000C5's Avatar
C52000C5
Thanks, I am gonna try to get a clip for you guys so you can hear what exactly this setup sounds like. But I'm sure it won't do it any justice
Old Nov 15, 2006 | 06:24 AM
nlreb54's Avatar
nlreb54
I had installed the same set up about 3 weeks ago on my 98 except I am running a Corsa cat back. I got a check engine light this weekend with a p0141 code. I cant locate any O2 sims anywhere. I am in the process of having it tuned now to get the CEL cleared.
I still love the system and the sound!!!
Old Nov 15, 2006 | 12:50 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Wow, those look like they are tucked in better than stock! Any issue with the front O2's hitting the plate? One of the reasons I haven't gone w/ a full-on header is I don’t want (or need) exhausts hanging down on my lowered car.
Old Nov 15, 2006 | 07:01 PM
nlreb54's Avatar
nlreb54
on my installation the front 02 sensors hitting the plate were an issue. what has anyone done to correct it?
Old Nov 16, 2006 | 10:39 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
I have the Dynatech's also. Great system. I had a smiliar problem with cat-back rubbing the bumper...what I did was disconnect the cat-back portion compleltly, and monkey around/adjust it again..it took a couple of times, but I got it so it would not rub. Sometimes the cat-back will adjust a little on it's own, just being under load when the car is running.
Don't resort to cutting just yet, that would be my last choice.
Good luck
Old Nov 16, 2006 | 11:55 AM
WKMCD's Avatar
WKMCD
Drill a couple large holes in the plate and pass the wires through them to keep them out of the way and keep the 02's from hitting.
Also, Turn your clamps up 90 degrees so they don't hit on speed bumps or collect trash on the road.
While you've got it down, get a stronger tunnel plate from Wilfullone.
Old Nov 16, 2006 | 01:57 PM
Rag-Top Rick's Avatar
Rag-Top Rick
Nice system!
You may want to rotate those clamps to the inside, out of harms way!
Old Nov 16, 2006 | 08:16 PM
blue99frc's Avatar
blue99frc
Originally Posted by R.P.
Nice system!
Old Nov 17, 2006 | 02:17 PM
Ryan L's Avatar
Ryan L
Wow, thats looks exactly like my set of 'ebay headers', minus the flange that connects to the cats. I used the same Torctite clamps as well. Very nice.
Old Nov 17, 2006 | 02:34 PM
jrose7004's Avatar
jrose7004
Did you install hi flow cats or just get rid of them?
Old Nov 17, 2006 | 04:01 PM
Ryan L's Avatar
Ryan L
Are you refering to me? I am running no cats and CEL eliminators.
Below is a pic from another member running the same set up. Only difference is the type of clamps I used. I think I paid a total of $400 including the clamps, new gaskets, etc.
Old Nov 17, 2006 | 04:07 PM
FRC Shopper's Avatar
FRC Shopper
Take your car to the track, and you'll be even more impressed. My car went from 13.08 at 108 mph to 12.66 at 112 mph with the Kooks.
Old Nov 17, 2006 | 11:57 PM
wayneinvirginia
Those are high flow cats on mine. I have already rotated the clamps around, my installer left them turned down like that. I haven't had any clearance issues with either the O2 sensors or the aft cat exhaust. And no CEL or codes to this point.
Old Nov 20, 2006 | 12:07 PM
wayneinvirginia
One other difference I notice in the Dynamaxx and the eBay headers is the length of the tubes. The collectors on the eBay headers are right next to the oil filter while on the Dynamaxx the collectors are several inches farther back. I'm no expert but I believe the longer tubes will increase the torque.
To FINALLY!! Headers are On!!!
