Aftermarket shift knob problem
Old Nov 13, 2006 | 10:50 AM
ls1mtz's Avatar
ls1mtz
Default Aftermarket shift **** problem
So I finally got sick of the stock square shift **** and bought a new one. I recieved a half leather/ half polished **** w/ a small Z06 logo on it. Nice looking piece, however it was a stupid universal one and used a 7 bushing system to ensure a perfect fit (which is just 7 different threaded plastic pieces with different size holes in the middle). What you do is just find the one that is close to the size of your stock shaft and screw it into the **** then onto the shaft. So basically the thread on the shaft taps the plastic, hold the **** on. Well this sucks everytime I start driving hard it spins. I have emailed the company that I bought it from but they will not respond. Has anyone had this happen? How can I fix it?
Old Nov 13, 2006 | 11:52 AM
gorillavet's Avatar
gorillavet
If it doesn't have set screws to tap into the shifter body, you may as well throw it away as it is a piece of junk. If it has the set screws just screw them into the shift shaft and forget the bushings.
Old Nov 13, 2006 | 01:32 PM
B-ras's Avatar
B-ras
I have a similar style shift **** that came with the same array of plastic bushings. When I tried to install with just the bushings, I could never get it tight enough to keep from spinning when I made hard shifts. I unscrewed it and wrapped a few layers of Teflon tape around the threads of the shifter shaft. Then I threaded the **** back on, and after it felt tight I used both hands to twist it another revolution into the correct alignment. It's stayed tight now for several road course events and four 1/4 mile runs on Sat night.
Old Nov 13, 2006 | 02:05 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If it were me, I would machine a bushing out of brass with the correct thread size for the inside and outside threads and install it with lock tight. But that just me!
Old Nov 13, 2006 | 03:46 PM
Dave68's Avatar
Dave68
This is why I thread my shift ***** directly and also use a locking collar to keep the orientation correct. I tend to stay away from anything that says "universal" on its packaging.
Dave
Old Nov 13, 2006 | 07:49 PM
Scott02Z06's Avatar
Scott02Z06
I would just get a new good quality **** built for C5's... universals are usually junk... just my .02
To Aftermarket shift knob problem
