Check Engine Light
Old Nov 13, 2006 | 02:29 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Default Check Engine Light
Pop quiz hotshots.
Someone told me that if the CEL is on, the engine runs on reduced power. True or False. The clock's ticking...........
Thanks people.
The Monk!
Old Nov 13, 2006 | 02:39 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
FALSE,,,,,,sort of!!! Depends on what DTC the CEL is reporting! If the DTC (problem) can damage the engine, it will cause the PCM to go into reduced power mode. If it is just an emissions related issue NO it will not cause it.
BC
Old Nov 13, 2006 | 03:28 PM
rws.1's Avatar
rws.1
Had a check engine light event and there was no change in power...
filled up with fresh gas and no more CEL event.
Old Nov 13, 2006 | 03:43 PM
SpeedyZ's Avatar
SpeedyZ
I agree with Bill, it all depends on what the PCM "thinks" is wrong if it will put the engine into reduced power mode.
Old Nov 13, 2006 | 08:24 PM
craig04c5's Avatar
craig04c5
More than likely you have a faulty gas cap. When you got gas you repositioned it and it sealed. This just happened to me and I just turned the gas cap and the light went out in about 5 mins. I got a new cap.
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
false
Old Nov 13, 2006 | 08:52 PM
cruisemon's Avatar
cruisemon
Originally Posted by themonk
Pop quiz hotshots.
Thanks people.
The Monk!
No oil, no coolant - she's a no run at full power.
The computer is trying to tell you something. Check the codes. Search the forum on how to do do and what the codes mean.
Charlie
To Check Engine Light
