turn signal light keeps exploding
Old Nov 14, 2006 | 12:52 PM
vmaquera's Avatar
vmaquera
Default turn signal light keeps exploding
The drivers turn signal light keeps "blowing". I believe it actually blows up, since fragments of the bulb are noticeable behind the lens.
Any idea of what could be wrong?
I have a '99 Coupe Z51/A4
Old Nov 14, 2006 | 01:04 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
That happened to me a couple of weeks ago on the p/side. The bulb burnt so I changed it, the second bulb blew up so I ended up changing the whole socket. I cut the old socket in half and saw that it was all corroded on the inside. The outside looked fine, but the inside had that aqua colored crap in it. It only cost me $70 CDN for the new socket and it's been fine since. Good luck.
The Monk!
Old Timer's Avatar
Old Timer
FWIW, more likely than not, you've got a crack in the top of the turn signal lense housing, which is letting moisture drip onto the bulb (when its hot) causing the bulb to burst.
Barry
Old Nov 14, 2006 | 04:08 PM
SpeedyZ's Avatar
SpeedyZ
Barry
Very common on these cars. The bulbs heat up the plastic housings right above the bulb causing the plastic to get brittle and crack. That lets water in directly over the top of the bulb. And we all know what happens to a hot bulb when dripped on with cold water! A good thick coat of silicone sealer over the top of the housing may fix the problem. Depends on how bad the housing in though.
Old Nov 14, 2006 | 07:35 PM
Neeko's Avatar
Neeko
i had both blow out on me too. Bulbs burn hot and are way too close to the housing. Removed both housings, cut a hole where the bulb melted the plastic and siliconed a blank from basic aluminum home electrical boxes. Did the trick, been dry and lit up for a couple years now.
Old Nov 14, 2006 | 08:22 PM
dwarmenzerk's Avatar
dwarmenzerk
i see, i have the same problem with my passenger side turn signal.. but i looked at the connection and the socket inside looked 'burned' and corroaded.. where could i get a replacement?
gm part # anyone?
Old Nov 14, 2006 | 11:05 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
Old Nov 15, 2006 | 03:54 AM
vmaquera's Avatar
vmaquera
Thank you gents.
As always, very helpful.
Vic
Old Dec 17, 2006 | 10:26 PM
1GM Vette Tech's Avatar
1GM Vette Tech
7th Gear
gm part # anyone?
Check this for the lens.
http://www.ecklers.com/product.asp?p...dept%5Fid=1476
Try your dealer or aftermarket for the socket "pig tail". Always use dielectric grease in the socket, I go through the stuff like mad at work! Very common problem! Make sure to cut your old wires off up the harness till you get nice bright copper wire. Also be sure to use the shrink style butt connectors so you don't have a repeat problem. Best o luck! You can fix it!
Old Dec 18, 2006 | 03:33 AM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
Another alternative is to install a new set of clear corners. More than likely you have a crack over the bulb from heat as others have stated. I recently replaced mine with a set of clear corners and they look great.
Old Dec 18, 2006 | 06:10 PM
UWEBABY's Avatar
UWEBABY
St. Jude Donor '06-'07-'08-'09
WHERE'D YOU GET YOUR CLEAR CORNERS? MANY ON EBAY STATE THEY ARE FOR SHOW ONLY, NOT DOT APPROVED.
Old Dec 19, 2006 | 01:15 AM
NocarbutaVetteforme
I'll get the name for you when I get home. I know it has a DOT number on it.
Old Dec 19, 2006 | 03:16 AM
TheDVS1's Avatar
TheDVS1
Depo lenses are DOT approved. I have a pair of their "black" lenses that Richard at Corvette Enhancements smoked for me. They look awesome!
Regarding the hot bulbs, has anyone tried an LED replacement for the stock bulb? Much less heat, but I believe you need a clear lense for the LED to put out the proper amount of light.
Old Dec 19, 2006 | 03:16 PM
chevyvette1's Avatar
chevyvette1
here is where water gets into mine, just to the right of the spring,just got my new clear "Depot" lights the other day, maybe they will go in yet tonight
Old Dec 19, 2006 | 08:36 PM
3 vettes's Avatar
3 vettes
Default Bulbs
I Had This Happen Too And I Found Out That You Need 4157 Bulbs.the 3157 Can Explode.the 4157 Is A Higher Wttage Heavy Duty Bulb.sylvania And Gm Have The Patent On The 4157
FLORIDA's Avatar
FLORIDA
St. Jude Donor '07
I had that problem on my 98. I bought a used turn signal light on this CF and a new socket with pigtails from NAPA. Even with the new socket be careful not to bend the terminals inside the socket when installing the bulb. The socket was expensive, about $30.00
Old Dec 20, 2006 | 11:51 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I bought a set on ebay 55 bucks. GM Exports I guess as they are GM marked with a part # I don't see any moisture in them like I did with the old ones. Appears that the grap plastic is thicker on top too.
To turn signal light keeps exploding
Old Dec 20, 2006 | 01:54 PM
chuckster's Avatar
chuckster
Here is your Fix...
http://forums.corvetteforum.com/show....php?t=1250530
Old Dec 21, 2006 | 02:20 PM
stngh8r's Avatar
stngh8r
very good, thanks chuckster
Old Dec 21, 2006 | 04:36 PM
LoneStarFRC's Avatar
LoneStarFRC
I went a slightly different approach. After first sealing the damaged area of the housing on top I cut a small piece of some Thermo-Tec material that has an adhesive on the back and inserted it through the bulb hole and stuck it to the area just above where the bulb sits. In effect it's just creating a "heat shield" from the inside. Been working well so far.
