Are memory settings retained if battery is removed?
Old Nov 15, 2006 | 12:25 AM
H20Vette's Avatar
H20Vette
Default Are memory settings retained if battery is removed?
Are the memory settings (driver's seat position, radio presets, a/c settings, DIC options, etc) retained if the battery is disconnected for a long period of time? ie, are they saved in non-volatile memory? Or do you lose all that?
Old Nov 15, 2006 | 12:51 AM
VetteNoob's Avatar
VetteNoob
Yes. Had the battery disconnected for 3 weeks while I modded the car and all was well when I was done.
Old Nov 15, 2006 | 02:49 AM
ZeeOSix's Avatar
ZeeOSix
I had the battery out for days, and when put back in I believe the clock was reset and the RANGE and MPG figures on the DIC were reset to zero. Otherwise, I think everything else stayed as is.
Old Nov 15, 2006 | 07:18 AM
BlackZ06's Avatar
BlackZ06
If you have a Delco radio with TheftLock turned on (red LED blinks when car is turned off) then either turn off TheftLock or be sure you have the radio code before disconnecting the battery. With TheftLock on the radio won't work after reconnecting without inputting the correct code.
See your Owner's Manual to see if your radio has this feature and more details on how it works.
Old Nov 15, 2006 | 12:01 PM
REW89's Avatar
REW89
Why can't we use those memory saver devices that plug into the cigarette lighter? I keep hearing we can't use them on C5's but I have never received an explaination as to why.
Bob
Old Nov 15, 2006 | 02:53 PM
Dave68's Avatar
Dave68
We don't need them!
Old Nov 17, 2006 | 12:06 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default battery
when I changed my battery, I used 10 gauge wires clipped to an extra battery clipped on the alternator battery lug and to the alternator bracket.
everything stayed good, and then unclipped the wires
To Are memory settings retained if battery is removed?
By Michael S. Palmer | 2026-06-03 09:39:05
