Diff. to Tranny Connection - Seal???
Old Nov 16, 2006 | 06:34 AM
vettenuts's Avatar
vettenuts
Default Diff. to Tranny Connection - Seal???
Getting ready to pull the trigger on a DTE rear. I have been reading up on the swap and looking at my core that will go to DTE for the build. This will be installed in an MN6 car. What keeps the rear diff fluid from spilling into the area between the tranny and the differntial and then leaking out? The auto's have a seal.
Old Nov 16, 2006 | 08:03 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
On the output shaft of the trans there is a seal, and on the diff. side it's a large O-ring, make sure you have a new one on hand for the re-install.
Old Nov 16, 2006 | 08:17 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Or a tube of permatex/silicone
Old Nov 16, 2006 | 08:35 AM
vettenuts's Avatar
vettenuts
I can't seem to find any mention of it in the service manual for the MN6, only the auto. Not sure why I am missing it, but the diff does appear to be an o-ring surface.
Old Nov 16, 2006 | 11:16 AM
Dan_the_C5_Man
It's a stretch but I might be able to find the part number for the O-ring for you. Better yet, just call Fred Beans, that's where I purchased mine from. You def. don’t want to re-use the old one. Make sure you lube up the O-ring with seal grease so it won't be pinched upon re-installation (one of the sources of diff. to trans leakage).
Old Nov 17, 2006 | 09:25 AM
George V's Avatar
George V
The part number for the O –Ring is 12369456
Old Nov 17, 2006 | 01:04 PM
Boob's Avatar
Boob
Put a bead of copper silicone one the oring and call it a day. I did this and have no leaks from the diff.
To Diff. to Tranny Connection - Seal???
