Muffler bypass tube
Installing the a bypass pipe is what's called the A&A Mod. for the Forum Vendor who first introduced it and a piece of 1 3/4" or 2" SS pipe will work. I had it done awhile back and it gives a deeper sound, but you'll probably be looking for something more later.
This mod gives you two very different sounds, from inside and out.
From inside, it's a good amount louder. A little higher octave than aftermarket exhausts, and fairly loud. No resonance or drone of course. I'd give the inside sound a B+, definitely an improvement.
From the outside; however...
The right word for the sound it makes at low rpm/idle would be 'embarrassing.'
It almost sounds like a diesel truck, sped up a little, and higher octave. In fact, it sounds very much like a tractor. Not the exhaust note of a tractor, but the engine sound, if that makes sense. The sound as if you were standing next to the engine.
Revved up, it sounds like stock but louder.
I wish I had a chance to record it before I tossed it for my Corsa TIs.
Let me tell you a short story. Right after getting it done, I took it to a friend's house because I wanted him to rev it up so I could hear it outside.
As I pulled up, he said "There's something wrong with your car!" And every chance he's had, he's ripped me on the sound it made since.
I'm thinking maybe if you didn’t make a smooth hole or made the hole smaller in diameter than the tube, you might end up with the negative results on idle. Could you post a short video or could clip so we can hear it at idle and revving?
I can host it for you, just email it to me. Thanks!
I did just think of one difference, my car is an 04 and therefore has precats, though I'm not sure those little cats would make that difference.
I'm thinking maybe if you didn’t make a smooth hole or make the hole smaller in diameter than the tube, you might end up with the negative results on idle. Could you post a short video or could clip so we can hear it at idle and revving?
. Did not want to do the same on the C5, with changing the exhaust system mulitple times. I want something to sound more aggressive than my wife Mercedes and her Expedition. I will try to post the sound clip this weekend.The Best of Corvette for Corvette Enthusiasts
