ABS/Traction control warnings
Old Nov 19, 2006 | 06:55 PM
michaeleverson's Avatar
michaeleverson
Default ABS/Traction control warnings
My car gets two warning lights when I drive over railroad tracks. Service ABS and service Traction control. What should I be looking for? Loose sensor? loose connection? Is this a common problem? My car is a 2002 Coupe A4. The lights reset themselves when the car is turned off. Next time I go over the tracks they come back on.
Thanks Laura (signed on my husbands account)
Old Nov 19, 2006 | 07:23 PM
jarsdad1's Avatar
jarsdad1
Check & post your codes. There are a number of possible causes.
Also, do a search, there are numerous posts about this and numerous solutions, depending on cause.
Old Nov 20, 2006 | 12:37 AM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
Keep us informed since alot of us have had this problem and some still do. I for one have been trying to chase down the cure for a while. Thanks for any information you find.
Old Nov 20, 2006 | 02:41 AM
DeeGee's Avatar
DeeGee
Bill Curlee posted a great How To on checking grounds to fix this problem. I would guess that this is more likely than a component failure as you're getting the snag when the car is being jolted. Just a guess though.
PM me and I can send a copy of Bills summary.
Old Nov 20, 2006 | 02:48 AM
rubyjames's Avatar
rubyjames
Default I'LL go one better.
I need to tag on to this post.
My Traction control does not selct on or off at all. When the ASR button is pressed nothing happens. I know handling is active when the rear wont break traction, but I can't deselect this, even though I shouldn't
Any help.
Old Nov 20, 2006 | 02:54 AM
DeeGee's Avatar
DeeGee
Any help.
Can you post your DIC codes. Could be a module has failed. In my case the problem was intermittent and they replaced the EBCM. The codes should give a clue whether its EBCM, BMPV or wheel sensor.
Old Nov 20, 2006 | 10:54 AM
Bill Dearborn's Avatar
Bill Dearborn
Any help.
Pull the switch panel and take a look at the connections on the bottom side. It could be something as simple as a wire off a connector.
Bill
Old Nov 23, 2006 | 02:20 AM
rubyjames's Avatar
rubyjames
I'll check out the panel underneath, thanks.
There were no codes thrown for the ASR. Just doesn't activate/ deactivate.
Old Nov 23, 2006 | 02:42 AM
guttermouth's Avatar
guttermouth
Looks like the TCS is sensitive on this car. Every time i turn off the TCS/AHS to do a few donuts right after i get done going around a few times it gives me the same error "service active handling".
Even though it was off during the donuts. But when i turn off the car and turn it back on everything is fine
Old Nov 23, 2006 | 10:00 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is the info that you need to figure out what DTC's are being set:
This is the absolute best C5 Code web sites!!!
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
Here is another very good site:
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
If it happens only after a shock event, you most likely have a bad connection somewhere in the harness/s. The front wheel sensors have a sh!& load of female connections that can go bad. The female pin fails and looses connection. I have a picture of a good and bad connector:
This is the jumper harness that has a tendency to go bad:
Here is the connector:
The connector on the LEFT is new. The one on the right is BAD!!!!
Post your codes and we can narrow it down to which wheel or component.
Bill Curlee
Old Nov 23, 2006 | 10:05 AM
Chevy Nick's Avatar
Chevy Nick
Bill, do you have a picture/instructions where we can find that jumper on the car? I think I have a similar problem? Does anyone have the GM part # so I could order a new one, seems like it would be pretty cheap.
Old Nov 23, 2006 | 02:23 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The jumper is EASY to locate. Just look on the back of the front wheel hub and you will see that it has a wire and a connector:
Front wheel hub with wire:
Rear wheel hub with wire:
On the FRONT HUBS the hub sensor connects to the jumper cable:
The jumper goes from the hub to the main harness connector on the fraim. Just follow it back and you will see that it is easy to find.
Happy Thanksgiving!!
BC
Old Nov 25, 2006 | 11:49 PM
JC in XTC5's Avatar
JC in XTC5
Your DIC codes will confirm where the problem is, but I agree with Bill that your issue is likely with an intermittent connector contact.
I had a one time issue with this ABS/TCS warnings and my DIC code was a LF wheel excessive wheel speed as I as slowly oulling out of a parking space.
I pulled the connectors for the LF wheel, checked all the wires and contacts, and added some dielectric grease. The problem hasn't come back.
Old Nov 26, 2006 | 12:29 AM
CMYC4GO's Avatar
CMYC4GO
With mine, it was the FR wheel. I cleaned all the connections on all the wheels, and a bunch of grounds. The problem has not returned.
Old Nov 26, 2006 | 12:34 AM
DansVette's Avatar
DansVette
I'm suddenly getting the same two warnings. My battery was completely dead (I mean as if the battery had been removed) after I charged the battery back up, then started the car, the warnings appeared. Never had them before.
To ABS/Traction control warnings
