Engine Operating Temp
Old Nov 20, 2006 | 09:09 AM
wnmech's Avatar
wnmech
Default Engine Operating Temp
My question is what temp should an LS1 engine run at? I just bought a 2001 formula with an LS1 engine and the operating temp seems to run at right around 210 degrees. No overheating problems but I am courious of what everyones run at? Thanks
Old Nov 20, 2006 | 09:12 AM
DeeGee's Avatar
DeeGee
Thats about the hottest I used to see even in a Vegas Summer. The fans cut in at about 220 I think. Seems a bit warm for normal running to me.
Old Nov 20, 2006 | 09:39 AM
mike348's Avatar
mike348
My LS1 runs at 197 on the road. In city it will be higher.
Old Nov 20, 2006 | 09:52 AM
wnmech's Avatar
wnmech
I guess I need to be sure if the gage is reading properly. I dont know if the fans kicked in or not. I just installed this engine could be I still have air in the system. Thanks for the info guys.
Old Nov 20, 2006 | 09:58 AM
robvuk's Avatar
robvuk
I run 192 on the highway. Higher of course in traffic.
The question is if you just installed the engine, what was in there before? If it was a smaller engine, you may have a cooling system that can't handle it. Make sure the radiator is clean. Vettes hav a tendency to collect "stuff" at the very top of the radiator and cut off half the capacity.
Old Nov 20, 2006 | 10:04 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
210° isn't that unusual for a car with factory fan turn-on settings.
Factory settings - turn-on temps for the fans are 226° and 235°.
Old Nov 20, 2006 | 10:42 AM
wnmech's Avatar
wnmech
The engine came out of a 2000 z-28 camaro and it went into a 2001 formula. The only reason I am posting here is because C-5 vettes have the LS1 engine. I usually hang in the C-3 section with my 77 vette. Thanks for all help.
Old Nov 20, 2006 | 11:06 AM
Jim2003's Avatar
Jim2003
My 03 mn6 runs 190 to 192 in town if driving not sitting, in traffic it will go to 220 or so then the fans come on. At highway speed 189 to 194.
Old Nov 20, 2006 | 11:48 AM
Tigershark3's Avatar
Tigershark3
192 as long as I'm moving - on a hot day in traffic I've seen it as hot as 220.
To Engine Operating Temp
