Plug Wires?
Old Nov 21, 2006 | 10:11 AM
XLR8BYU's Avatar
XLR8BYU
Default Plug Wires?
I'm feeling a slight hesitation every now and then at low to mid-range RPM's (2200-3600) on acceleration. I know I need a tune, but it also feels like I may have a bad plug wire I need something to do while waiting for turkey on Thursday so I think I;ll change the plugs and wires.
What spark plugs/ plug wires is everyone running?
Old Nov 21, 2006 | 11:10 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
NGK TR 55 and Moroso 8mm Spiral Core Wires.The plugs and wires have 50,000 hard miles and still running strong. www.moroso.com
Old Nov 21, 2006 | 11:39 AM
Tigershark3's Avatar
Tigershark3
I put a set of GM Performance wires and NGK Copper TR55 plugs. It was time to change as they had almost 70k on them but I did not really notice much difference as the car ran good before the change. Not an expert but if your engine was misfiring I'd think you'd see codes and/or you check engine light would be on. .02 deposited.
Old Nov 21, 2006 | 12:48 PM
Former Vendor
Default Misfire
After installing headers I experienced an intermittent misfire that was caused by a burnt plug wire. For some reason it never threw a code and the check engine light never came on.
To Plug Wires?
