yES But only in Carbon Fiber as you found. Just as suttle, one a 3/4" wider. If I put a BBK up there I would need the wider front fenders too.
My 18-305/30s just fit under the fender, but from the front you can see tire. I did make some gurney flaps ( like the C6Z06) for the leading edge of the front wheel well. But that is to creat a negative pressure air zone on the out side of the wheel to suck air though the wheel and cool the brakes.
From: Buy USA products! Check the label! Employ Americans
wonder why front are CF only? What is the weight difference? I guess it is the same mold and he could do both.
hey kevin from what i remember reading, he used to work for specter werkes, can't wait to see them as i might be intereseted in giving you a little winter project, he also sold a whole wide body kit based on specter werkes and there c5r fixed lights, Matt.
