Oil Pump ?
Old Nov 24, 2006 | 02:09 PM
Vassili's Avatar
Vassili
Default Oil Pump ?
Where is it and also the MAP sensor.
Old Nov 24, 2006 | 02:20 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Originally Posted by Vassili
Where is it.
Around the crank behind the timing chain.
Old Nov 24, 2006 | 03:22 PM
vettenuts's Avatar
vettenuts
MAP is on back of the intake manifold.
Old Nov 24, 2006 | 05:15 PM
Laguna Blu's Avatar
Laguna Blu
So apparantly it pays to upgrade the oil pump at the same time that a timing chain is upgraded? Would seem to save on the labor
Old Nov 24, 2006 | 09:12 PM
cruisemon's Avatar
cruisemon
Plus I'd blueprint the puppy, clean it out thoroughly, shim the pressure relief valve with a .060 - .100 shim to kick the pressure up, port the inlet and outlet to improve flow if it's OEM pump. Or put in a high flow pump. It's hard to have too much oil flow unless you run 20W-50 in zero degree weather and get on it too hard before the oil warms up - then the oil filter makes sort of a "poink" noise and unloads the system at the gasket (don't ask).
Charlie
To Oil Pump ?
