Running hot..160 stat.
The fans have no clue what thermostat you have installed, they are driven by command from the PCM, which also has no clue what thermostat you're running.
1) With the engine STONE COLD check the coolant level in the overflow (recovery) tank and make certain that the coolant level is at least at the MINIMUM level (duhhhh ... sorry to be so obvious
)2) If the level is good, and you heard gurgling at 226, I'd be tempted to think the radiator cap may be going bad. With the engine still cold remove the radiator cap and check to see if the coolant level is at the top of the radiator. If there is air in there, then the cap isn't functioning properly.
3) If you decide to replace the cap, be certain to get the right type. I believe our caps are 16 PSI, but more important the cap has to be the type that works with the overflow (recovery) system. Obviously the dealer should have one, but a good parts store like NAPA should also carry the right part.
Other than the gurgling (which may well have been normal if the coolant system hasn't got really hot in a while), the engine getting to 226 is nothing to worry about. Sitting in traffic on a hot California day I will see the coolant hit 230 to 235 and then drop to about 220 as the fans kick into HIGH speed mode. If I continue to sit in traffic the coolant temp will cycle back and forth as the fans kick in and out of high speed mode.
Finally, you really can't overheat your engine .... read the section in your owner's manual (look in the index under ENGINE, it is listed as "Overheated Engine Protection Operating Mode") .... pretty (sorry for the pun) COOL technology.
HTH
HTH
In my opinion a colder thermostat only does two things ...
1) Makes the engine take longer to come up to "normal" operating temperature. This wastes fuel, and a cold engine is less powerful than a hot one since the heat (energy) being used to warm the engine is less energy available to power the car
2) If you live somewhere like, say, Cleveland, and take the car out when it is 20 below zero (OK unlikely a Corvette owner will do this ... but bear with me) with a 160 thermostat you'll get a warning message that the engine is actually running too COLD ... the PCM wants to see the engine temp in the 190+ range, and a 160 thermostat on a REALLY cold day may not let the engine get warm enough. (DTC P0128)
HTH
HTH
HTH
I have run my 160 since new in 2000 and have NEVER gotten a too cold code, even when driving in the 20's. Consider: the PCM commands the car to go closed loop (normal operating characteristics) based on several inputs. The minimum temp for it to go closed loop is in the 120's, WAY below what you will see with a properly operating 160 thermostat.
The checks you suggested are good, I would add when it is started stone cold, monitor the temp gauge and keep a hand on the upper radiator hose. When the thermostat starts to open you will feel the warm water starting to flow. It it gets above 160ish and the hose is still cold your thermostat isn't opening properly and could be your problem.
1) "Lower coolant thermostats are reported to INCREASE Hydrocarbon emmisions by as much as 30 percent, at 160 degrees, as indicated in SAE paper #950163" (Quote is from Corvette Fuel Injection - by Charles O. Probst - Bentley Publishers ISBN 0-8376-0861-9)
If you're getting increased HC ... you're not efficiently burning the fuel.
From The Design and Tuning of Competition Engines - by Philip H. Smith - Bentley Publishers ISBN 0-8376-0138-X
"For the engine to be efficient, in every meaning of the word, it must burn its fuel to the utmost possible advantage from the point of view of power production. If as big a percentage as possible of the heat energy is converted to work on the pistons, good design will take care of the disposal of the remainder which is unavoidably wasted." (page 47 - section entitled "Water Temperature")
Note that heat that is disposed is "wasted". If your engine is running at a lower temperature than mine, you are "wasting" more heat - which is power. The limiting factor to engine temperature is fuel pre-ignition caused by hot engine surfaces. The ideal engine temperature (and hence coolant temperature) is as high as you can get it without pre-igniting the fuel. The engineers that designed the LSx engines knew what they were doing when they specified a 195 degree thermostat. Don't you thing they'd have specified a 160 if they thought it would make the engine run better ????
2) While you may not have gotten a P0125 or P0128, you also may have and not realized it, as the first time either of those DTC's set they do not turn on the Check Engine Light. The fact is the PCM checks the rate at which the coolant temperature is rising and it WANTS to see a rapid rise. Just 'cause you may have dodged that "bullet" doesn't mean that the PCM isn't looking for a fast rise in coolant temp. Running a 160 degree thermostat slows the ENGINE's coolant jacket temperature rise. With a 195 thrermostat the ENGINE coolant quickly rises to 195 before the engine now has to "heat" the water in the radiator. With a 160 degree thermostat the engine only reaches 160 before it has to start heating the coolant in the radiator, and therefore spends much longer at a lower temp than a car with a 195 thermostat.
HTH
I agree that the best coolant temp is the highest you can run without preignition. However, that temp is really about 180, not 195. At 180 you can retune to run more timing, or at least reduce KR that you would have been getting at 195 plus (just opening there, not steady state).
I have been involved in many dyno tunes on LS1/6 Vettes and all made more power at/about 180, not 200 degrees.
When I say I haven't had any too cold codes that's from checking for them through the DIC and through a Predator data checking device, not by "dodging the bullet" and not seeing a CEL.
GM picked the running temps for very good power and lowest NOx emissions, not the best power.
HTH
I run the stock thermostate, 192 or so.
What does a 160 degree thermo. do that a 192 doesn't do ??
It only opens sooner, nothing else, when both are open they both allow the same amount of flow.
The idea is to get the engine up to temp. fairly quickly and keep it there, most of your engines wear occurs at cooler temps. Normal operating temp. is around 195 or so, say 200.
Never warm up your engine by letting it idle, get in start it up and then as soon as it "cleans up" (only a few seconds) drive it away slowly, being very gentle with it, it warms up faster when you drive it.
If your car is running warm, start checking things. Change the coolant AND flush the engine, get those lime deposits out of there. (Use distilled water)
Clean the radiator by spraying it with a hose backwards, from the fan side to the front of the car, take it out if you have to.
Install a radiator grill of some type, not too fine of a screen.
Change the radiator cap, I think the new ones are 18 PSI.
I do not know what the C5 water pump looks like, but on other engines ... One thing I found most people miss is the water pump body to impellor clearence, too much clearance and it will not pump the proper amount of fluid, so if your've changed the water pump and then it starts running warm, this may be the reason. I'm not sure what the clearence should be but I bet it says in the service manual.
Oh yea, check your thermostate, make sure it does open at the right temp. Use a candy thermometer and a pot of boiling water on the stove, the wife and kids love when I do that.
