oiling problem
Old Nov 26, 2006 | 06:41 PM
firstc5's Avatar
firstc5
8th Gear
Default oiling problem
2001 ls1 rebuilt , having problem getting oil too the top of the motor. I have three rockers two on drivers side and one on pass side getting oil, have check pressure at oil filter housing reads 50 psi. any thoughts would be greatly appreciated.
Old Nov 26, 2006 | 08:03 PM
dpd's Avatar
dpd
where th cam bearings replaced????
Old Nov 26, 2006 | 08:32 PM
firstc5's Avatar
firstc5
8th Gear
yes new cam bearings
Old Nov 26, 2006 | 09:17 PM
chriswtx's Avatar
chriswtx
the top of our motors gets the oil first, then the cam bearings and then the main bearings..
Old Nov 27, 2006 | 02:12 PM
waupachino's Avatar
waupachino
An easy check would be the Push Rods, pull them out and make sure the passages are clear. Next would be the lifters.
Old Nov 27, 2006 | 03:03 PM
Just Enough's Avatar
Just Enough
If a couple of the cam bearings weren't lined up properly during installation that would prevent oiling of those respective lifters/rockers.
Old Nov 28, 2006 | 10:44 PM
firstc5's Avatar
firstc5
8th Gear
new lifters/pushrods were intalled.GM manual (as above) show top of motor gets oil first. Was curious if anyone knows if the rearoil gallery plug could have moved?, preventing full oil flow up the gallery. oil pressure gauge in car reads 000000000. pulling motor back out to check bearings
Old Nov 29, 2006 | 05:42 AM
vettenuts's Avatar
vettenuts
Check the gallery plug in the front as well. Also, cam plate leakage.
To oiling problem
