Which gears for automatic?
Old Nov 29, 2006 | 12:57 PM
yankeevetteconvert's Avatar
yankeevetteconvert
[QUOTE=chaase]If you have 2.73 go to 3.42. It will be a world of difference. If you are going to put in a converter, go to 3.73.. I have 2800-3000 stall converter and 3.42 and I find myself having to drive faster to get better gas mileage. The 3.73 would eliminate that issue.
The stall on the converter eats up too much power below 1700rpm so I drive closer to 70mph to get the best mileage.
Chris[/QUOT
Your TC should be in lock up mode at those speeds and hence you should get the same mileage. My TC locks up at 38 MPH in OD. Now I lose mileage due to the gear(3.73) on the highway but not to the TC.
Old Nov 29, 2006 | 02:49 PM
chaase's Avatar
chaase
St. Jude Donor '12
Originally Posted by yankeevetteconvert
Your TC should be in lock up mode at those speeds and hence you should get the same milage. My TC locks up at 38 MPH in OD. Now I lose milage due to the gear(3.73) on the highway but not to the TC.
It does lock-up and you would think it wouldn't matter but it does...If I could get a flat highway with noone around it wouldn't be an issue, but since I have to make minor speed corrections for hills, traffic, it seems the engine bogs more at lower RPM and a require more pedal input to get the change in power/speed that I need.
Maybe I am wrong and it is attributable to the altered power curve, but I noticed a difference
Chris
Old Nov 29, 2006 | 03:31 PM
yankeevetteconvert
Chris
Wow!
With my 3.73 I can accelerate in OD from 1400 RPM with the TC locked. No stumbles/bogs just a smooth acceleration. Hoowever I still have the stock cam. How big a cam are you running?
Old Nov 29, 2006 | 03:52 PM
chaase's Avatar
chaase
St. Jude Donor '12
Wow!
That is probably the difference, you have the 3.73. I am only running 3.42's and mid-high 220's cam (don't know exact specs). The couple of hundred rpm makes a difference to the way the car feels (at least to me)
Here is my dyno if it helps at all...
Chris
Old Nov 29, 2006 | 03:59 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
3.90s are the ULTIMATE GEAR for C5 A4 trannied cars when it comes to 1/4 mile performance. You will only spin about 100 to 200 rpm higher vs. 3.73s and with the overdrive tranny its a NO BRAINER. Just ask JOHNNY VETTES he just installed on in his 2000 A4 C5 and HE LOVES IT!!
Also, ROGER WHITE of yesteryear, had 3.90 gears in the fastest 1/4 mile cam only and heads and cam only C5 with A4 and stock shortblock, coupled with his YANK PROTHRUSTER 4000 Converter!! 4.10s would als work jsut fine, just ask RANDYVETTES!!!
Old Nov 29, 2006 | 04:06 PM
Blue02ws6's Avatar
Blue02ws6
if you drive on the highway any I would go no higher than 3.73. 3.42's would be a great middle of the road gear. You will get plenty of fun from them and not have the hassle of high rpm highway driving.
Old Nov 29, 2006 | 05:06 PM
bonnell's Avatar
bonnell
Originally Posted by kingsey
How mutch would these changes cost installed?
I'd be interested in the cost to go from 2.73 to 3.42 also. I don't have the knowledge or equipment to do this so I'd like to know a typical cost installed.
Old Nov 29, 2006 | 05:17 PM
Mopar Jimmy
St. Jude Donor '06
You would be surprised that to see that the 3.90s only spin about 150 to 200 rpm higher than 3.73s and what the heck is the difference (when you really think about) between spinning at 2600 rpm or 2800 (with an overdrive tranny). It is only a neglible difference and may $100 a year in fuel tops!!
Old Nov 29, 2006 | 05:22 PM
slolane's Avatar
slolane
CI 7-8-9 Veteran
St. Jude Donor '07-'08 & '12
I paid 3,000 for gears, converter, and dyno tune installed. Best money I every spent on mods
Old Nov 29, 2006 | 07:40 PM
Mike Mercury's Avatar
Mike Mercury
I truly believe that. And if I was as dedicated to the dragstrip as many others here, I would of went -at least- to the 3.73
Old Nov 29, 2006 | 10:26 PM
Blue02ws6's Avatar
Blue02ws6
2822rpm at 80mph in overdrive is crap for the highway. I wouldn't do 3.90's. It only drops to 2700rpm for 3.73's but that is a little lower, I had 3.73's in an auto and I've had 3.42's in an auto. I would go with 3.42's for a DD that sees highway use and 3.73's or 3.90's if it hardly ever sees the highway.
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
You can get a rear end carrier for $1100-$1300. I got mine used for $600. It cost another $600 to have the dealer (yep, chevy dealer was the cheapest place I found) install it.
Old Nov 29, 2006 | 10:28 PM
  #33
Blue02ws6's Avatar
Blue02ws6
Paid $625 for gear swap with hardened output shaft. Can't go wrong when it is cheap and PERFECT.
Old Nov 29, 2006 | 11:07 PM
  #34
Mopar Jimmy
St. Jude Donor '06
This is all subjective and relative to any given individual, to me the motor is barely working at 2822 rpm and is BEGGING for more RPM!!! SO i spend an extra $100 a year in fuel, big freakin deal!
Old Nov 30, 2006 | 06:02 AM
  #35
I'd stick with the 3.42s. You will notice a nice improvement over the 3.15s.
Old Nov 30, 2006 | 09:45 AM
  #36
waupachino's Avatar
waupachino
I would be careful when purchasing a used rear if you are not installing it yourself. If you get a bad one, you will be paying labor to remove it also and then you have to start all over with labor costs again. Lets just say I learned the hard way, and ended up buying a new one eventually.
Old Nov 30, 2006 | 09:51 AM
  #37
bob guzzy's Avatar
bob guzzy
Default rear
I had a3.15 in my 94, and it was a nice hwy. and local driveing rear, but it doesn't do much for you gas mileage, It would only do 18.
Where the 88 I had, was 2.59, a little slow but great mileage,
To Which gears for automatic?
Old Nov 30, 2006 | 11:29 AM
  #38
Mike Mercury
This is all subjective and relative to any given individual ... SO i spend an extra $100 a year in fuel, big freakin deal!
couldn't agree more. Our Corvettes are our fun car... not a mini-van. Have fun in your Vette, get the great gas mileage in your mini-van taking the kids to & from soccer practice.
Old Nov 30, 2006 | 12:19 PM
  #39
Blue02ws6's Avatar
Blue02ws6
You should put in 4.56's then those would be much more fun.
Some people actually have to drive on the highway even in their vette's, not to mention the people that use them as DD. I have had an auto with 2.73's, 3.42's, and 3.73's and a manual with 3.42's, 3.73's, 3.90's, 4.10's, and 4.30's. I think I can make an educated guess as what would be a good all around gear for most people.
Old Nov 30, 2006 | 02:48 PM
  #40
Gohard777's Avatar
Gohard777
Originally Posted by brian vette
Went from 3.15 to 3.73 on the highway it revs about 2400 rpm at 70 mph for me that is just a little high so I drive 65 mph. Unless you drag race everyday don't go above 3.42 want a 3.73 rear ?
Thanks for the reply. What would the rear cost, do you still have it or was that a joke, what about this hardened axle I keep hearing about, I'm new to Vettes, Thanks.
