Reverse problem with my built MN6 - thoughts?
Old Nov 28, 2006 | 08:50 PM
Payne's Avatar
Payne
Default Reverse problem with my built MN6 - thoughts?
I have a built MN6 in my z06, and am having problems with reverse...
Its not the lockout solenoid, as i can move 'over' just fine.
Its the 'up' part that doesnt work to save my life. It takes 100lbs of force to get it into gear with the motor running, or about 5lbs with the motor off.
Never kicks out, never grinds, its just engaging reverse that is the problem...
The clutch is slipping badly, so its coming out this weekend for a rebuild, as well as a new slave.
Im guessing/hoping its the clutch dragging causing the problem... Thoughts?
-Jason
Old Nov 28, 2006 | 08:55 PM
dpd's Avatar
dpd
if it goes into gear easy with the engine off,it's a clutch problem
Payne's Avatar
Payne
But why only reverse? 1-6 are okay...
-Jason
Old Nov 28, 2006 | 09:20 PM
dpd's Avatar
dpd
you're probably fighting the reverse idler gear.
Old Nov 29, 2006 | 12:24 AM
vettchic's Avatar
vettchic
3rd Gear
I had the same problem, it turned to be the hydraulic fluid reservior was low on fluid.
Old Nov 29, 2006 | 12:26 AM
Payne's Avatar
Payne
I did some experimenting today, the clutch is dragging.
-Jason
Old Nov 29, 2006 | 09:59 AM
Vetteoholic's Avatar
Vetteoholic
-Jason
*Theres your answer right there, get a new clutch & make sure to get a lighter flywheel as well. It will be cheaper to do them both since the whole assembly will be out of the car. I would have It looked at 1st just to make sure though. I went with the Fidanza 12.5 Lb flywheel & I love It! Best of luck~
To Reverse problem with my built MN6 - thoughts?
